» Tpc LS adapter plate
» Headers, headers, HEADERS!
Pulling Turbo Engine, What To Keep?
Post  Bluemach1 on Tue May 21, 2013 1:12 pm
Finally back on this after a very long break.
Pulling out the old turbo engine. Is there anything I need to keep besides the radiator and expansion tank?
I aleady have a new harness.
Bluemach1
Re: Pulling Turbo Engine, What To Keep?
Post  marc a on Tue May 21, 2013 7:06 pm
For street or track car:
Fuel Tank vent (hard line running up the firewall on passenger side)
Fuel supply and return lines if you want to run a return system with an external regulator/fuel pressure gauge.
8 pin connector and about a foot of the harness connected to it (connector is on the fire wall on driver's side) for switched power and some other convenient connections.
Oil pressure sensor wires.
Water temp sensor wires.
Two wire harness going to alternator and solenoid.
For street car . . . . . . a lot more wiring
Probably just a start . . . . .
marc a
Post  Bluemach1 on Tue May 21, 2013 10:01 pm
The car is an 86 turbo. It is for street and I already had the motor harness made some time ago (SST made it it think).
Other than the fuel lines I dont think there is much else I need. (and wiring marc noted)
for AC - do I keep any of the Porsche stuff? Or does all the plumbing get scrapped?
Oil cooler - any use for the Porsche stuff?
Radiator - I already have a custom aluminum one. I have a set of fans.
any other big stuff to keep?
Bluemach1
Post  87-944S on Tue May 21, 2013 10:14 pm
For A/C, you can keep the Porsche stuff and modify the compressor, or plumb in the GM controls which is easy. That is what I did.
Post  marc a on Wed May 22, 2013 7:00 pm
Ted,
If you want to use the oil cooler, metric to -an adapters are available. Make sure you use a thermostat between the oil source and cooler.
I have a mocal cooler that is about twice the size of the OE and it keeps oil temps below 250 during the summer. I would check to see if chevy ran oil coolers on the OE installations.
Marc
marc a
