Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
1986 Turbo Options - Help
Post  Bluemach1 on Tue Sep 01, 2009 12:47 pm
I am looking at a 86 turbo. The owner gave me the option codes. Two of them I can not identify. 141 and 142.
Anyone know what these are?
Bluemach1
Re: 1986 Turbo Options - Help
Post  Bluemach1 on Tue Sep 01, 2009 1:22 pm
here are the codes i was given. co2 141 142 474 533 650 666 900 and 946
No 220 for the LSD? Was this std. equipment for the 1986 turbo?
Bluemach1
Post  robstah on Tue Sep 01, 2009 1:33 pm
I too have an 86 turbo. It's either open or the previous owner burnt the clutches up. My transaxle does have the cooling setup on it as well and I just wonder why they would put such a setup on an open setup.
Post  m73m95 on Tue Sep 01, 2009 1:45 pm
Here's a complete list of option codes.
m73m95
Post  Bluemach1 on Tue Sep 01, 2009 2:04 pm
Thanks. I had checked clarks, Rennlist and 944online and others but still cant figure out 141 and 142 are....
Bluemach1
Post  Bluemach1 on Tue Sep 01, 2009 3:49 pm
So I had the guy double check the codes again. He verified 141 and 142. Anyone know what these are?
Options dont list 220 (LSD) but he did confirm that the trans code is "5R" (oil cooler w/ LSD according to Clarks Garage). Does that seem right that it would have one but not the other?
Also, he says that the car has air conditioning but option codes does not have "559". Does this seem right?
Any help is greatly appriciated.
Bluemach1
Post  948 on Tue Sep 01, 2009 7:35 pm
Where did the trans code come from, the trans itself or the option sticker????
It does have the Koni Shock option, 474. Check and make sure they are there.....
Post  Bluemach1 on Tue Sep 01, 2009 7:54 pm
Trans code "5R" came from the sticker. From Clarks it should be oil cooled with LSD. The Koni's are probably long dead, no?
Last edited by Bluemach1 on Tue Sep 01, 2009 7:55 pm; edited 1 time in total (Reason for editing : R5 to 5R)
Bluemach1
Post  dallas on Tue Sep 01, 2009 8:09 pm
The only true way is to read the number off the trans itself. My friend has a couple open turbo trans that have coolers. I was surprised that porsche did that. Clutches add heat to the oil. I have a 944s lsd that doesn't have a cooler. But its an 87 trans. Get under the car with a mirror and read the numbers on what would be a bellhousing normally.
dallas
Post  Bluemach1 on Tue Sep 01, 2009 8:56 pm
so the option sticker doesnt necessarily represent what the actual items are? I dont know if i will be able to get underneath the car...
Anyone know what options 141 and 142 are?
Bluemach1
Trannys can get changed.
Post  dallas on Wed Sep 02, 2009 6:23 am
Unless Your buying from the original owner, and its a low mileage car. Its pretty much a crapshoot. I've had 3 trannys in mine since I've owned it. I finally got the 944turbo s trans I wanted. Even the numbers can be wrong if someone installed a torsen lsd unit. Highly unlikely for a non tracked car though.
dallas
Post  948 on Wed Sep 02, 2009 6:38 am
Bluemach1 wrote:Trans code "5R" came from the sticker. From Clarks it should be oil cooled with LSD. The Koni's are probably long dead, no?
My 86 has the 474 Koni option and a trans with LSD/Oil cooler, but I still verified it when I purchased it 8 years ago. The Konis are still in great working condition at 115,000+ miles.
If the shocks are worn out Koni can rebuild them for less than new, usually.
Post  Bluemach1 on Wed Sep 02, 2009 8:46 am
Thanks for the input. Thats good information about the Koni's!
Bluemach1
Post  944ls on Wed Sep 02, 2009 11:28 am
Might want to jack 1 rear wheel off the ground and try to turn it. if it turns freely it is an open diff. If there is resistance but will turn with force it is a clutch style posi / limited slip. if ti is locked solid it is a locker or spool (un likely) I cant remember what a good break over tork number would be for these units. Eian at 944 online would know.
944ls
Post  m73m95 on Wed Sep 02, 2009 11:51 am
^^ make sure you leave it in neutral. If you leave it in gear and only spin one wheel, it will be locked.
Its better to have BOTH rear wheels off the ground, then spin one wheel (still in neutral). If they turn in opposite directions, open diff. If they turn in the same direction, LSD
m73m95
Post  Bluemach1 on Fri Sep 04, 2009 10:23 am
I am going to inspect the car Saturday.
To locate the trans code, can it be seen from the engine compartment? On clarks it says you will need an inspection mirror and a flashlight. I am assuming that this is done from the top and not from underneath the car?
One more thing, the owner says that compression test is 150, 150, 150, 170. I am not positive on what would make that one cylider run so high. Is oil getting in there? Any thoughts?
Anything else that is a MUST to investigate? (keeping in mind that the engine is coming out)
Ted
Bluemach1
Post  944ls on Fri Sep 04, 2009 10:42 am
The number is on the top of the trans housing in the back of the car. very hard to see. the number is on the top center of the bellhousing over the coupler. must be seen with a mirror from under the rear of the car.
944ls
Post  Bluemach1 on Fri Sep 04, 2009 11:09 am
Thank you, I had my orientation all wrong.
Can you tell I have not owned a 944 before?
Ted
Bluemach1
