» Transaxle rebuild
Today at 8:51 pm by yamamtx
Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
Would this radiator work?
Post  zeusrotty on Sun May 19, 2013 3:23 pm
It also has a trans cooler. Can I use that as an oil cooler? Or maybe a power steering cooler? I'm guessing I'd want a two row for road racing correct? Also, I'd have to add a bung for the fan switch, and weld the filler cap shut. Am I missing anything?
zeusrotty
Re: Would this radiator work?
Post  87-944S on Sun May 19, 2013 4:19 pm
Use the GM fan control and you will not need to weld a bung in for the fan switch
Post  zeusrotty on Sun May 19, 2013 4:51 pm
Ah, I didn't think of that. I can't remember if its wired that way or not. It's been a year since I took it apart... I'll check tomorrow.
zeusrotty
Post  Admin on Sun May 19, 2013 7:27 pm
It would fit, Would it "WORK" that would need to been determined....Does not look to have any more core than a factory turbo radiator...
Post  zeusrotty on Sun May 19, 2013 8:18 pm
I'm worried that the turbo radiator wont pull enough air through it with a condenser in the way for track days. Do you have a suggestion? Id probably use the 3.8 Taurus fan with whatever I get. They seem to pull the most air. I'd ;ike to find something under $400.00 if that is possible. What are the biggest exterior dimensions we have to work with?
zeusrotty
Post  Lemming on Mon May 20, 2013 7:01 am
For that price you can get a good Griffin radiator that is a closer fit.
Post  docwyte on Mon May 20, 2013 8:24 am
Depends how hot it gets near you. The Turbo radiator was working pretty well for me, it would get hot, but no hotter than the CMC racecars. It also recovered very quickly.
I have the Ron Davis radiator now, it fits better as far as hose routing goes, takes longer to get hot, is a little cooler than the turbo radiator but takes longer for it to recover.
Post  Rich L. on Mon May 20, 2013 10:20 am
I got a big fancy Wizard radiator. Doesn't cool any better than the turbo rad did.
Post  zeusrotty on Mon May 20, 2013 11:19 am
So maybe just use the 2 row Griffin radiator with the Taurus fans and make sure it gets tons of air huh? I keep seeing drag race in the descriptions for them so it makes me think it may not work well for Road racing. LOL
zeusrotty
Post  docwyte on Mon May 20, 2013 11:45 am
I cut open that license plate area on my 951 bumper. Between that and not running the front license plate at the track it's worth almost 20 degrees.
Post  spence on Mon May 20, 2013 11:48 am
The griffin rad #1-26201-x fits as well as the summit rad - #SUM-380645
I used the summit rad and it fits nicely with ford contour / mercury cougar v6 fans.
Post  zeusrotty on Mon May 20, 2013 2:10 pm
The one you are using is a single row, and I don't think that will work well for the track. I think I am going to go with either the Griffin 1-85201-H or the Griffin 1-26201-D... And then use the Ford Taurus fans...
The H model has two rows of 1.5 inch tubing and the D has 2 rows of 1 inch tubing but it has a trans cooler in it so griffin thinks it will cool better. Does that make sense? The D is also cheaper by 200.00, but I would have to have the filler cap welded shut.
zeusrotty
Post  zeusrotty on Tue May 21, 2013 10:31 am
So I pulled the trigger on the Griffin Aluminum Circle Track Radiators 1-85201-H
I also found out something interesting. Apparently the early 90's Volvo V70 or S70 has a fan just like the ford fan that also comes with or can be gotten with a controller from the factory. here is the link to the forum and post that I found it on. There is also a youtube video.
zeusrotty
