» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
First Drive LS3
First Drive LS3
Post  thom on Wed May 15, 2013 9:22 pm
Hello guys, Milkman and myself finally took the LS3 conversion for it's first ride. WOW super cool!!! Looking forward to finishing it up and track it. I posted a gopro video on youtube.
thom
Re: First Drive LS3
Post  Techno Duck on Wed May 15, 2013 9:31 pm
Badass! What a Face
Re: First Drive LS3
Post  bluejk09 on Thu May 16, 2013 8:52 am
Awesome! I look forward to more pics and videos.
bluejk09
Re: First Drive LS3
Post  thom on Thu May 16, 2013 9:53 am
Here's another with a drive by view.
thom
Re: First Drive LS3
Post  Admin on Thu May 16, 2013 10:54 am
Pretty cool, how'd you make it sound like a leaf blower? Razz Razz Razz Razz
Re: First Drive LS3
Post  thom on Thu May 16, 2013 11:18 am
Admin wrote:Pretty cool, how'd you make it sound like a leaf blower? Razz Razz Razz Razz
New 2 stroke LS3. Very Happy
thom
Re: First Drive LS3
Post  thom on Mon May 20, 2013 12:58 pm
[img][You must be registered and logged in to see this image.][/img]
thom
Re: First Drive LS3
Post  Admin on Mon May 20, 2013 7:31 pm
What accessory drive set up are you using?
Re: First Drive LS3
Post  thom on Mon May 20, 2013 9:22 pm
This is the kit that was installed. We deleted the P/S pump and A/C and measured for the correct length serpentine belt. We will be replacing the self adjuster with a manual one.
thom
Re: First Drive LS3
Post  Rich L. on Mon May 20, 2013 11:00 pm
Yeah, good. I had the belt jump off the spring tensioned self-adjuster this spring. Everything seems good now with the clamp tensioner instead.
That air cleaner looks great as long as you keep air pressure in front of the rad.
Re: First Drive LS3
Post  thom on Tue May 21, 2013 6:55 am
Thanks Rich, We still have a lot of work to do as in fabricating a wall to separate the air filter and radiator. It's just nice to see a light at the end of a tunnel.
thom
Re: First Drive LS3
Post  thom on Fri Aug 15, 2014 7:55 pm
It's been on the road for some time now and finally had it on the dyno for a tune. We were able to put down 468hp to the wheels. Car has been trouble free since the build. Looking forward to a track day this year to test it out properly. Hopefully we can get Techno Duck there on the same day.
thom
Re: First Drive LS3
Post  Techno Duck on Sat Aug 16, 2014 6:28 am
October 4th and 5th at NJMP!
Re: First Drive LS3
Post  Lemming on Sat Aug 16, 2014 8:25 am
Nice, now get it out there and flog it on the track!
Re: First Drive LS3
Post  XtaC on Fri Aug 22, 2014 12:01 am
Nice work Thom!
I'm going to run a similar floor mounted Tilton setup.
Mind divulging the cylinder sizes you are using for the brakes and clutch?
Thanks mate,
Lee.
XtaC
Re: First Drive LS3
Post  Raymond-P on Sun Aug 24, 2014 4:10 pm
Thom....468 HP to the wheels is outstanding!! I think you're going to have a lot of GREAT track days.
Reopening your thread called my attention to your engine bay and like XtaC I'm very interested in your brake and clutch set-up. I used Holley valve covers with LS2 coil packs in My LS1 build and I would like to keep my PS and keep my coil packs on the covers.
I also love your air intake approach as well!
Nice job!!
Ray
Raymond-P
Re: First Drive LS3
Post  thom on Sun Aug 24, 2014 7:26 pm
Ray and Lee, I ended up using Tilton 75 series pedals with .625 " front master, .700" rear master and .875 for the clutch. We are also using a Quicktime bellhousing so the shim calculation was a little more complex due to the mounting surface of the slave in the bellhousing. We also use a remote brake bias set up. This helped balance it out a great deal more. The front calipers were changed over to Big Reds and the rears are stock turbo blacks. If you search for "floor mounted Brake Pedal" you will find additional information and photos from other users also. Good luck with you cars. Thom
thom
Re: First Drive LS3
Post  thom on Sun Aug 24, 2014 7:34 pm
Also Ray, to do the intake without it hitting the hood, I lowered the radiator mount enough to clear the aluminum tube. Basically cut and rewelded the lower mounting rail and extended the upper retaining bolts with bushings.
Thom
thom
Re: First Drive LS3
