Yesterday at 10:58 pm by 948
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
Hood clearance
Hood clearance
Post  msmoorenburg on Mon Aug 31, 2009 10:08 am
Here are a few pictures of my hood clearance without shims on the xmember. I plan to put a hood scoop on the car when I find one I like, But my question is has anyone run the lt1 setup without shims and just modding the hood rib. After the rib is removed I believe I will have about a 1/4 inch of clearance for motor movement. And comments?
msmoorenburg
Re: Hood clearance
Post  948 on Mon Aug 31, 2009 11:40 am
I lowered my engine and cut the support ribs.....
Re: Hood clearance
Post  944ls on Mon Aug 31, 2009 12:32 pm
I am having a hard time seeing how much room is there. What intake and TB is that?
944ls
Re: Hood clearance
Post  msmoorenburg on Mon Aug 31, 2009 1:20 pm
944ls wrote:I am having a hard time seeing how much room is there. What intake and TB is that?
Its all stock 94 lt1
msmoorenburg
Re: Hood clearance
Post  944v8inDFW on Mon Aug 31, 2009 4:32 pm
I have done several with little or no mods to the hood ribs, and have NEVER shimmed a cross member on LTx or LSx conversions. Major deal is the height of your motor mount uprights and of course oil pan clearance. As stated in another thread check the condition of your trans mount first, then look at motor mounts.
944v8inDFW
Re: Hood clearance
Post  944-LT1 on Mon Aug 31, 2009 8:25 pm
I never did anything! No xmember spacers or cutting/notching. It just fit nicely. The TB boot touched the brace but I think all of them do.
Just get some silly putty and see how much clearance there is. If less than 1/4 inch, I would be surprised.
But then again, all 944's are a bit different and ALL have been crashed. Mad Theres no exception....and if youre the original owner....the factory pre-crashed it for ya!
Re: Hood clearance
Post  xschop on Tue Sep 01, 2009 9:23 am
""And Comments?""
Are you missing a socket extension from your tool cabinet? Laughing
What pan are you using?
Re: Hood clearance
Post  Tetzuoe on Tue Sep 01, 2009 9:35 am
Laughing thats where I keep my extensions too.
Gonna have to check out my transmission mount, I used spacers AND notched the hood to get my LS in, the motor mounts put the pan pretty close to the xmember, I just dont see how the motor could fit wihtout all that stuff.. unless my trans mount is completely screwed.
though the factory installed front end collision probably used forces little understood by modern science to torque my frame just right.
Tetzuoe
Re: Hood clearance
Post  msmoorenburg on Tue Sep 01, 2009 9:42 am
xschop wrote:""And Comments?""
not yet Smile that extension is like 2 ft long Shocked
the oil pan is a modded stock pan
msmoorenburg
Re: Hood clearance
Post  xschop on Tue Sep 01, 2009 9:47 am
Anyone running a solid tranny mount?
It can be modded further to bring the rear of the tranny up and front motor down some more even from stock. I crawled under to take a look this weekend. It will be on my hit list soon.
Re: Hood clearance
Post  948 on Tue Sep 01, 2009 11:06 am
xschop wrote:Anyone running a solid tranny mount?
Mine has been since the conversion was done....though I still had to mod the hood etc
Re: Hood clearance
Post  RobotMachines on Sat Oct 03, 2009 9:50 pm
I just ground down the ribs and it's been fine with my LT1 (I used the old RH full kit).
Edit: I used regular mounts and no spacers... just the grind of the hood.
RobotMachines
Re: Hood clearance
Post  bluehellfire666 on Mon Jul 19, 2010 12:32 pm
originally i had a big hood scoop...turned out i didn't really need one, i just took two little notches out of the hood ribs and the hood closed perfectly, i could actually close it without notching the hood, but i didn't want it rubbing and putting stress on stuff. I'm running home made mounts and modded stock oil pan, no shims
bluehellfire666
Re: Hood clearance
