Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
928 LS conversion kit with 2-piece bellhousing
Post  xschop on Sat May 11, 2013 12:25 pm
Complete LS engine to 928 5-speed manual conversion kit. Comes with refurbed C5 2-piece bellhousing and exhaust hanger bracket(citric acid washed, etched and painted)…..All new CNC machined T6061-T6 billet bellhousing to 928 torque tube adapter with all hardware including 928 torque tube flange bolts and washers. New CNC machined 4140 chromoloy steel engine mount adapters with 1.5” rearward adjustability if you decide you want to install the Corvette torque tube and Getrag 6-speed transmission later (it fits the 928). Mounts also come with all new hardware and are used with factory GM mounts (98-2001 Camaro) . Also included is a brand new factory GM pilot bearing specific for this LS application..….100% BOLT-ON
$835 shipped Will ship UPS Ground…..US-48 ONLY…Just PM
