Stabilizer Factory Defect?
A continuation of my post - Stabilizer HELP!
Re: Stabilizer Factory Defect?
Here are some pictures to my prototype. It is 0.134" cold rolled steel. I need to adjust one hole and do some contouring for a better fit but you can see that it should work nicely. Once it is dialed in, I will get it powder coated. This one is for the passenger side. I already have the templet for the drivers side but just have to punch the holes.
Rennmetal makes a very nice bracket that runs from the crossmember mounting point to the bottem of the stabilizer that will really help beef this thing up. I will just buy from him, no need to reinvent the wheel.
Ted
Ted
That's on my list of "to do's" as well...however, remember that the dimensions will be different for our cars because of the crossmember relocation (so you might as well make your own).Bluemach1 wrote:Rennmetal makes a very nice bracket that runs from the crossmember mounting point to the bottem of the stabilizer that will really help beef this thing up. I will just buy from him, no need to reinvent the wheel.
Ted
