Flywheel question for early sbc 2 pc rear main seal
Hey guys! I'm using a early sbc 2 pc rear main seal engine. Also have the c5 bellhousing. Am I ok to go by the manual and use 168t flywheel ( it says for the 1 pc rear main seal)? I just don't wanna order the wrong part. Also, should I still use the ram #78125 t/o bearing? And also, I shouldn't need the pilot bearing adapter, right? Thanks for ur time! Clint
931Clint- Posts : 8
» Rear Crankshaft Seal
» Question about rear drive shafts.
» How do I mod an early tach for a V8 signal?
