» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
California Smog Conversion
Page 5 of 5 Previous  1, 2, 3, 4, 5
Re: California Smog Conversion
Post  pormgb on Tue Feb 21, 2017 3:19 pm
mrmartini101 wrote:Thanks for the reply,  I must have had a brain fart.  I thought I was sending a request to TH944.
Thanks for all of the info.  I did read your Ca smog conversion posts.  Nice job.
Reading about the EROD motors and the fact they make some very impressive HP and they are CARB approved, is very attractive.  Just a little pricey.  I guess it's going to come down if I can find a good F body motor with all of the smog.
On the LS conversion forum.  Some were talking that the CARB inspectors said they needed the donor cars fuel tank.
I'm also in San Diego.  If possible I'd love to see your car, maybe pick you brain a little.
Sure, I'm in north SD, send me a PM if you would like to see the conversion.
You don't need the donors cars fuel tank, the inspector looked for all the EVAP components but never asked about my fuel tank.
The inspector that done my car printed a picture of a 2002 LS1 with all associated engine emission components, he then checked my car to make sure I had the same components.
The fuel tank components (fuel level sensor, fuel pressure sensor) are used for the readiness cycle. I installed a fuel pressure sensor in the top of my fuel tank and used a resistor on the fuel level circuit to emulate a 3/4 full gas tank.
pormgb
