Have a early 350, but can I use the LT1 parts? EmptyYesterday at 11:51 am by geegeesbits@gmail.com
Have a early 350, but can I use the LT1 parts? EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
Have a early 350, but can I use the LT1 parts? EmptySun Jan 26, 2020 4:51 pm by j7wolfe
Have a early 350, but can I use the LT1 parts? EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
Have a early 350, but can I use the LT1 parts? EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
Have a early 350, but can I use the LT1 parts? EmptySat Jan 18, 2020 7:15 am by Rothaus
Have a early 350, but can I use the LT1 parts? EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
Have a early 350, but can I use the LT1 parts? EmptyThu Jan 16, 2020 2:11 am by Golten1986
Have a early 350, but can I use the LT1 parts? EmptyTue Jan 14, 2020 2:48 pm by Gumby
Have a early 350, but can I use the LT1 parts? EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
Have a early 350, but can I use the LT1 parts? Empty Have a early 350, but can I use the LT1 parts?
Post  931Clint on Tue Mar 26, 2013 7:56 pm
Hey guys! New to the site! Plan on being here for a while...lol! My question is, will these LT1 parts work for swapping in my early model Chevy 350? I would guess late 60's or early 70's. I'm just wondering if I could use the same c5 bell housing and adapter and also the same engine mount setup? I'm not to familiar with the LT1's, and I'm not sure if they changed things around since then. Any info would be greatly appreciated!! Thanks guys, Clint
931Clint
Have a early 350, but can I use the LT1 parts? Empty Re: Have a early 350, but can I use the LT1 parts?
Post  944-LT1 on Tue Mar 26, 2013 10:39 pm
Yes to all. The mounts between the LT and Gen1 engines are the same so you're safe there. As well, the C5 BH/adapter will bolt up fine.
Post  xschop on Wed Mar 27, 2013 9:49 am
If you use an SBC or LT1 you do not have to have a pilot bearing adapter. Use GM part# 12557583 Smile
Have a early 350, but can I use the LT1 parts? Empty 350
Post  931Clint on Wed Mar 27, 2013 11:41 am
U guys rock!!
931Clint
