928 5-speed kit
+6
haroldk
attes
Amille28
charlie1175
abarthel
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 928 5-speed kit
It looks like I forgot to say "Thanks for the kit!" in here. My kit looks good and hopefully I can get back working on my 928 soon. Still need a few more bits before I can start swapping.
However, I've also been talked into helping a friend put a 383 LT1 into a 928 5-speed he just picked up. The OE Porsche engine is DOA, and I'd like to work with your kit for this swap because he may change his mind (again) at some point and decide to change over to an LS mid-swap. I know you mentioned needing a spacer (.4" ?) with the LT1, but was that with a C5 two piece bell housing or with a C4 6-speed bell housing? We have a ZF 6-speed on hand with the OE bell housing. I just have not had time (and enough warm weather) to get the LT1 off the engine stand and and start test-fitting things.
Thanks!
Thanks!
erioshi- Posts : 227
Re: 928 5-speed kit
You would need to add 0.40" plate between C5 bell housing adapter plate and retention tube to fit an Lt1.
Re: 928 5-speed kit
Thanks! Exactly the information I was looking for.
Re: 928 5-speed kit
Rob can you give me an email. Have a few questions and a kit for an auto.
Psi_101 at hotmail dot
com
Thx,
John
com
Thx,
John
dozman- Posts : 1
Re: 928 5-speed kit
I've got 2 adapter plates and extention tubes ready to go. Engine mounts not included but I will email tech drawing as they are easy to make.
$385 shipped US-48 only. Just PM
Re: 928 5-speed kit
Mind dropping me an email or PM with the drawings? I still need to put a set of engine mounts together for the race car. I figure working from the drawings should be more precise than trying to copy an existing set of mounts.
Re: 928 5-speed kit
Shoot me an email at [You must be registered and logged in to see this link.]
I'll send you the pic as I don't have scanner at shop ok.
And again, you can mount the 928 automatic with these adapters. You need to get the 928 AUTO front coupler and mate it to Chevy flex plate.
The 928 Auto is a super strong Mercedes trans FYI.
any more 928 LS kits or parts left?
xschop, do you have any parts left? If not how about tech drawings?
Gumby- Posts : 1
Page 2 of 2 • 1, 2
Page 2 of 2
