Yesterday at 3:52 pm by matt889
Yesterday at 11:38 am by chrenan
» Clutch master cylinder
Sun Jun 17, 2018 8:40 pm by Arthropraxis
Sat Jun 16, 2018 9:43 am by JP914
» WTB : Coil over setups !
Fri Jun 15, 2018 2:26 pm by matt889
» For Sale: Turn One Power Steering Pump & F-body conv kits
Tue Jun 12, 2018 10:35 pm by jHo
» For sale $150 Griffin for LS1 LS Radiator swap
Tue Jun 12, 2018 7:51 pm by HGT1
Tue Jun 12, 2018 6:17 pm by AMFCSL
» 5.3 conversion on 88 Turbo
Tue Jun 12, 2018 6:39 am by tsimpson
Mon Jun 11, 2018 10:04 pm by Luke714
June 2018
SCCA Practice Event
SCCA Practice Event
Post  skywalker01 on Sun Mar 17, 2013 8:27 pm
Thanks to a healthy dose of polycarbonate and delrin suspension upgrades over the winter (not to mention thicker torsion bar), the car handles WAAYYYYY differently now. Even with the cold temps, I represented well taking 1st place in XP - and beating a couple of the Factory 5 Cobras that smoked me last season.
skywalker01
win
Post  kevin924kevin on Mon Mar 18, 2013 1:31 pm
Skywalker, nicely done. Keep it up.
Re: SCCA Practice Event
Post  944convert on Mon Mar 18, 2013 5:13 pm
impressive…most impressive.
Post  skywalker01 on Mon Mar 18, 2013 6:59 pm
I STRONGLY recommend that anybody that performs this conversion check the insertion of the driveshaft into the pilot bearing. I chewed up a TT (along with broken bellhousing), because I didn't initially take the time to do it. Like the saying goes "an ounce of prevention . . . . ."
skywalker01
Post  eclou on Mon Mar 18, 2013 8:16 pm
very nice! The wide torque band of these motors really lends itself to this. What cam are you using? Sounds like you were in 2nd & 3rd gears?
eclou
Post  skywalker01 on Mon Mar 18, 2013 8:25 pm
eclou wrote:very nice! The wide torque band of these motors really lends itself to this. What cam are you using? Sounds like you were in 2nd & 3rd gears?
This is a bone stock '98 LS1. Hot Cam will during the off season - I'm afraid I wouldn't be able to get it installed and tuned before the real season starts. As for gears, I wanted to grab 3rd gear, but not having power steering, I decided to run the course in 2nd. Running 285s on the front on a course like this is a real workout!
skywalker01
Post  eclou on Tue Mar 19, 2013 7:24 am
Have you done the rod bolts yet? My 98 LS1 motor lasted 20 minutes on track before throwing 2 rods. I found out the hard way about the weak 98 rod bolts Sad
eclou
Post  skywalker01 on Tue Mar 19, 2013 4:55 pm
No - would probably be one of the things that I would do when upgrading the cam. Thanks for the information on the weakness of the engine.
skywalker01
