More little problems
Ok so i have a 2000 corvette ls1 in my 944 and i bought the f body ps pump and alternator mount and when i tried to mount a belt i noticed my stock harmonic balancer and tensioner were both about a quarter inch off of alignment from my new f body stuff, do i need an f body balancer and tensioner or is something wrong?
Also on another note i have the TPC oil pan and my stock dip stick doesn't fit. Do i need a different stick or is something wrong?
tkrame944- Posts : 101
Re: More little problems
I cant be the only on who has had these problems? Any feed back is greatly apreciated.
Yes. The corvette balancer is different than the fbody balancer. I went with a 2002 camaro balancer from Rockauto DORMAN Part #594127 {GM#12553118} Diameter; 7-1/2"; Width: 3-21/32"
Chances are, youre going to need an Fbody waterpump as well.
Thank you, and did your stock oil dip stick work?
You'll probably have to bend the dipstick housing a little to clear the hood. Should work fine though.
Im going to have to look closer at mine then because it doesnt go into the block all the way.
I seem to recall it being a little hard to get in the block, but everything should work just fine. If you need to trim it you can cut a length off the housing, then use the length of housing you cut off to measure the amount to remove from the dipstick.
» Hydroboost problems
» LM7 conversion (Oil pan problems)
» 944 ls1 swap brakes and transaxle problems.. (Legal in Sweden)
