» Headers, headers, HEADERS!
» Electric brakes
Need help!
Need help!
Post  Tim on Tue Mar 12, 2013 5:02 pm
Hey all. I was about to put on my Quicktime bellhousing (RM-6033) and the hydraulic slave from Tick (http://www.tickperformance.com/gm-slave-cylinder-throwout-bearing-for-ls1-f-body/, but they don't seem to work together properly. What is the correct hydraulic slave to use with the RM-6033?
I have everything ready to complete the swap and should be done this weekend if I can figure out what to do here.
Any help would be appreciated.
Tim@OEMPartHaus dot com
817-304-0624
Tim
http://www.OEMPartHaus.com
Re: Need help!
Post  Admin on Tue Mar 12, 2013 5:36 pm
The Ram throw out bearing , part number 78125.
And you will need a bearing retainer from a T10 transmission as well.
Re: Need help!
Post  Tim on Tue Mar 12, 2013 5:48 pm
Thanks, does the one you sell have what I need also?
Btw, are you talking about this for the T10 retainer?
Tim
Re: Need help!
Post  Admin on Tue Mar 12, 2013 8:16 pm
Yes that ebay item will be part of what you need.
The parts that I sell only work with the adapter plate set up.....
You will need the Ram throw out bearing.
Re: Need help!
Post  Tim on Tue Mar 12, 2013 9:47 pm
Gotcha, thanks for the help.
Tim
Re: Need help!
