Yesterday at 9:03 am by chrenan
Fri May 25, 2018 8:34 pm by superman22x
» WTB: 944 Turbo Roller
Thu May 24, 2018 8:32 pm by knight76
Thu May 24, 2018 7:52 pm by matt889
» New here needing help
Thu May 24, 2018 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Wed May 23, 2018 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
May 2018
78910111213
14151617181920
21222324252627
28293031
Fix to only hot air through the vents
Post  docwyte on Tue Mar 12, 2013 1:09 pm
So my car has been doing this for quite some time. Turns out it's very common on the 944's to have this happen, there's a small plastic clip that holds the heater flap control rod that breaks.
It's up underneath the dash, above your right knee. Later 944's have a plastic cover, held in place by 2 screws that you have to remove. Later cars also have 2 rods. This is what mine looked like, you can see one is still in place and fine, the other one is hanging loose, hence only hot air. The plastic bushing and clip cost about $1.30...
Re: Fix to only hot air through the vents
Post  docwyte on Wed Mar 13, 2013 7:56 pm
And here it is fixed. I still need to get one more clip, I have the rod ziptied in place for now.
Post  gdopnt on Wed Mar 13, 2013 9:54 pm
Very common. After the clip goes bad the system defaults to heat so if its winter you dont loose visibility.
gdopnt
Post  turboswede on Tue Jan 14, 2014 4:04 pm
Also the vacuum diaphragm for the control valve can fail to full hot, which is what happened on my 951.
turboswede
Post  WoodenSpoon on Thu Jul 14, 2016 8:32 am
I have this problem as well. What's the part number on that clip/where did you get it?
WoodenSpoon
Post  docwyte on Thu Jul 14, 2016 8:41 am
You can find the part # on Clarks Garage, I got it from my dealer, super cheap...
Post  Techno Duck on Thu Jul 14, 2016 6:38 pm
WoodenSpoon wrote:I have this problem as well. What's the part number on that clip/where did you get it?
