» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
914 Headlight motor issues, help!
Post  docwyte on Sat Mar 09, 2013 11:21 am
So the 914 headlight motor is in, clocked properly and wired.
The 944 driven motor works fine, pops up, turns out, goes down.
The 914 headlight motor works, turns on/off, goes down and stays down. However........
When you turn it on, it repeatedly cycles up and down. It doesn't seem to know it's "up" stopping point. We've grounded it seperately to the main chassis ground, that enabled it to know the "down" stopping point, but it still cycles in the "on" position.
Scratching my head over here, any clarification would be appreciated!!
TIA!
Re: 914 Headlight motor issues, help!
Post  948inVA on Sun Mar 10, 2013 9:18 am
I think the ground connections play a big part in the operation of these motors. On my car, they seem to work fine when the engine bay is cool but start acting up once they get a little warm. (I assumed this was just a ground issue) I also had the same problem as you initially, but I think it was because I hadn't grounded the center pin (87a). That connection keeps the motor from overshooting it's position, which causes the cycling. Also double check your relay and make sure your relay connections are solid.
948inVA
Post  docwyte on Sun Mar 10, 2013 9:37 am
I wired in a new, modern Bosch relay, so no worries with that. I did ground 87a, that's what gave the motor it's stopping point in the "down" position. Or maybe I have something crossed? Are there two grounds needed, one for stopping positions in up and down?
Post  948inVA on Sun Mar 10, 2013 11:11 am
I think there were 2 contacts that I connected to ground.. I'll have to check my wiring and get back to you.
948inVA
Post  948inVA on Sun Mar 10, 2013 4:03 pm
Looks like I have terminals 85 and 87a connected to ground. I think 85 is the brown wire which grounds through the motor casing and bracket. I found that to be a bad connection, so I ran both grounds to a different point on the frame rail.
948inVA
Post  docwyte on Sun Mar 10, 2013 6:02 pm
Ok, I'll break out pin 85 to a distinct ground and see what happens, thanks!
Post  docwyte on Fri Mar 22, 2013 8:40 pm
Got it figured out. It wasn't a ground issue, we had the switched power hooked up wrong to the motor, so it was just constantly getting a cycle signal.
They work great and the motors are almost perfectly synced.
Post  Modian on Sun Mar 24, 2013 9:40 am
Is there a write up somewhere or a list of parts for switching to the 914 motor?
Modian
Post  docwyte on Sun Mar 24, 2013 9:56 am
Search this site for dual headlight motor conversion or 914 headlight motor. You'll find a thread with pics, wiring diagram etc
Post  backpack09 on Wed Mar 27, 2013 1:15 pm
backpack09
