LS1 from an Auto transaxle car
What would you guys recommend for a reasonably priced set of parts for the back of the motor to convert from auto to manual on an oem auto ls1?
endrnet- Posts : 129
Re: LS1 from an Auto transaxle car
Thats what im doing. To convert my auto LS3 to manual LS3:
Flywheel (12571611) 250
Clutch disc (Centerforce# CTF-383946) 163
Pilot Bearing 75?
Pressure plate (24248985) 300
Manual bellhousing (12554980) 179
Throwout bearing assy. (89059282) 135
Roughly 1100 by GM prices.
Are you looking for used parts?
Pilot Bearing 75?
Not opposed to used parts, necessarily, especially if they're not mechanical/moving parts. One reason is that as you listed prices, a cheaper auto transaxle motor might not be much cheaper, once in the car.
In my case, I'm not looking for performance parts, I'm fine with "stock/reman" parts for the conversion. This 944 already had 150k on it, and I want to leave some budget room to replace other wear items that are not conversion related, but probably need replacement, perhaps the ring/pinion, etc.
I seem to remember Marc a got the , pressure plate, clutch disc as a package from GM for 600, he ordered a LS6 setup.
Mike
Mike
