Need help!
Need help!
Hey all. I was about to put on my Quicktime bellhousing (RM-6033) and the hydraulic slave from Tick (http://www.tickperformance.com/gm-slave-cylinder-throwout-bearing-for-ls1-f-body/, but they don't seem to work together properly. What is the correct hydraulic slave to use with the RM-6033?
I have everything ready to complete the swap and should be done this weekend if I can figure out what to do here.
Any help would be appreciated.
Tim@OEMPartHaus dot com
817-304-0624
817-304-0624
Re: Need help!
The Ram throw out bearing , part number 78125.
And you will need a bearing retainer from a T10 transmission as well.
Re: Need help!
Thanks, does the one you sell have what I need also?
Btw, are you talking about this for the T10 retainer?
Re: Need help!
Yes that ebay item will be part of what you need.
The parts that I sell only work with the adapter plate set up.....
You will need the Ram throw out bearing.
