Few Questions
Few Questions
Say I buy the LS1 kit, what all else am I going to need other than headers and/or how much money am I gonna have to spend afterwards? This is assuming I have the engine, and 944.
Also I found a 944 NA w/o engine for $550 what all would I need to make it suitable for a swap other than turbo tranny and brakes?
Also another thing that wasn't really mentioned in the How to would a 944s be up to a swap without any conversion?
Sorry if this has been asked before, but thanks for any help.
celery- Posts : 2
Re: Few Questions
If you haven't already, spend some time reading through the threads on this site.
I've been here for at least a couple years and haven't even started my conversion. In all that time, I've learned the answer to a lot of your questions and I am certain there is a significant amount I still don't know. On top of that, there will be always be issues specific to your conversion that will come up.
A few things I can think of in addition to the kit (just off the top of my head):
A bell housing;
A solution for the braking system, hydroboost or other depending on your use;
Cooling system if your N/A radiator is insufficient for your use;
Power or manual steering and the associated bits;
Engine accessories such as an alternator, power steering pump, etc depending on the motor you source;
Engine management, again this may or may not come with your motor but you will need to have an ECU programmed in the end;
All that and I am no expert by any stretch.
A bell housing;
cjbcpa- Posts : 60
Re: Few Questions
The Wiki at the top of the page has a list of things to buy. Some of the part numbers are wrong but it will give you an idea.
