Steering Wheel Quick Disconnect
I am making a quick connect steering wheel system and did not want an after market steering wheel. (OK, I'm cheap and did not want to spend the money!)
Had to do some machine work to get it this far
Will just have to push in on the rubber boot to disengage the steering wheel. No one will ever know it is there!
Re: Steering Wheel Quick Disconnect
That's cool. I want to build a tilt-up column adapter, but that looks good to. So basically it lets you use the stock steering wheel?
Yes you can bolt the factory steering wheel back on....
Anybody know what's the spline pattern on these columns?
I didn't bring my steering wheel with me to work today.... LOL
The xschop wheel quick disconnect mod is next up.....
By the pic there it seems the weld at the bottom can be lathed off and a shorter extension welded on for the ebay 1.5" quick disconnect universal adapters....
