Header collection gaskets EmptyMon Apr 15, 2024 7:28 pm by JW1970
Header collection gaskets EmptyMon Apr 15, 2024 6:59 pm by JW1970
Header collection gaskets EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Header collection gaskets EmptyFri Apr 12, 2024 3:07 pm by Rob44
Header collection gaskets EmptyWed Apr 10, 2024 10:09 pm by LS982
Header collection gaskets EmptyTue Apr 09, 2024 8:45 am by gwistrup
Header collection gaskets EmptyTue Apr 09, 2024 1:54 am by lowform
» WANTED: 948 Conversion Manual
Header collection gaskets EmptyMon Apr 08, 2024 1:52 pm by Elskeptico
» FS 1989 Transmission for 944
Header collection gaskets EmptyTue Apr 02, 2024 10:02 am by 87roadracer
Header collection gaskets EmptyTue Apr 02, 2024 6:00 am by 89EFhatch
+3
7 posters
Header collection gaskets Empty Header collection gaskets
Post  acorad Thu Jan 17, 2013 5:25 pm
What kind of header collection gaskets are you all using? I've just had a second one blow out, it almost looks like some kind of compressed paper material (maybe asbestos?).
Header collection gaskets Empty Re: Header collection gaskets
Post  Arthropraxis Thu Jan 17, 2013 5:59 pm
I read on LS1tech.com that the original metal gaskets are better.
Post  Admin Thu Jan 17, 2013 6:52 pm
At the head or the collector?
Post  marc a Thu Jan 17, 2013 7:42 pm
I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Once I figured out the centering problem the the steel mesh versions have held up well.
Marc
marc a
marc a
Post  944-LT1 Thu Jan 17, 2013 8:02 pm
marc a wrote:I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Marc
Yup! Same thing here except I used alignment weld rings tacked to the pipe side which centered the gasket.
Post  87-944S Thu Jan 17, 2013 8:17 pm
Never saw those before, nice solution!
Post  Admin Thu Jan 17, 2013 8:35 pm
These work well for me
Post  acorad Thu Jan 17, 2013 10:23 pm
Admin wrote:[You must be registered and logged in to see this image.]
Thanks, but what is that?
Post  Admin Fri Jan 18, 2013 9:44 am
That is a ball style collector, The ball goes into the header flange and then you just weld your exhaust pipe onto the end of that.
Post  948 Fri Jan 18, 2013 11:33 am
Also known as Header Buddy / Buddies
