» Transaxle rebuild
» Tpc LS adapter plate
Belt squeal after hydroboost?
Post  Porch on Fri Jan 25, 2013 2:57 pm
I added hydroboost to my system a few months ago and have been battling some belt squeal since then.
The squeal occurs only after the engine has gotten nice and warm (after a longer drive), and only on deceleration.
I believe the squeal is coming from the power steering pump. I have already replaced one suspect idler pulley and put in a new alternator (the old one had a squeaky bearing). Everything else is in great shape! I have not replaced my belt, but i have a spare standing by. The current belt is a nice gatorback which has ~40k on it, but no cracks or weird wear. I just don't think it's the problem!
I wondered if maybe my powersteering fluid is getting too hot. I have a small cooler up front but could definitely afford to go larger.
I also wondered how people plumbed their return lines. My two return lines (one from the rack, one from the hydroboost) are tee'd together with a brass tee about one inch below the reservoir.
Steering and brakes are both working great. Any ideas?
Re: Belt squeal after hydroboost?
Post  948inVA on Sat Jan 26, 2013 4:39 pm
The only time I've experienced belt squeal was when I had a minor cooling hose leak, and it was leaking coolant onto the belt. It would make the belt squeal for a few seconds on startup.
948inVA
Post  Admin on Sat Jan 26, 2013 4:59 pm
Double and triple check your belt alignment. That is the only belt problem we have had. Also make sure the belt is the right length. Just a 1/4" makes a difference. I have run the hydro boost setups without a cooler with no heating problems.
Post  Porch on Sun Jan 27, 2013 10:37 am
Okay, good to know! I just wanted to make sure i didn't need a cooler and my "T" connection was okay.
I'm certain the belt is the right length. I have started to wonder if i spilled something on the belt while i was doing the swap. I'll just swap it out and go from there.
