» Headers, headers, HEADERS!
» Electric brakes
Header collection gaskets
Post  acorad on Thu Jan 17, 2013 5:25 pm
What kind of header collection gaskets are you all using? I've just had a second one blow out, it almost looks like some kind of compressed paper material (maybe asbestos?).
Re: Header collection gaskets
Post  Arthropraxis on Thu Jan 17, 2013 5:59 pm
I read on LS1tech.com that the original metal gaskets are better.
Post  Admin on Thu Jan 17, 2013 6:52 pm
At the head or the collector?
Post  marc a on Thu Jan 17, 2013 7:42 pm
I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Once I figured out the centering problem the the steel mesh versions have held up well.
Marc
marc a
Post  944-LT1 on Thu Jan 17, 2013 8:02 pm
marc a wrote:I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Marc
Yup! Same thing here except I used alignment weld rings tacked to the pipe side which centered the gasket.
Post  87-944S on Thu Jan 17, 2013 8:17 pm
Never saw those before, nice solution!
Post  Admin on Thu Jan 17, 2013 8:35 pm
These work well for me
Post  acorad on Thu Jan 17, 2013 10:23 pm
Admin wrote:[You must be registered and logged in to see this image.]
Thanks, but what is that?
Post  Admin on Fri Jan 18, 2013 9:44 am
That is a ball style collector, The ball goes into the header flange and then you just weld your exhaust pipe onto the end of that.
Post  948 on Fri Jan 18, 2013 11:33 am
Also known as Header Buddy / Buddies
