Fiberglass hood bubble
I'm looking online for a small fiberglass hood bubble so I can hide the hole in the hood for the throttle body. I've seen them on people's cars, but can't find one online. Everything I find is a huge drag strip style hood. Can anyone point me to a source?
money pit 951- Posts : 101
Re: Fiberglass hood bubble
IFC has a neat cowl induction hood scoop, Skywalker is using one.
Thanks! Wasn't aware of that company.
I already have the fiberglass hood, but have a small hole in it to clear the throttle. Just trying find a small fiberglass bubble to hide the hole. But will look into that hood at it would solve lots of problems
That's just the hood scoop. What brand hood are you using?
Consider using a 924 turbo fiberglass scoop.
disasterman- Posts : 4
This is the one that I use on my car, but I use it backwards from the catalog pic. [You must be registered and logged in to see this link.]
Thanks guys for the responses. I bought a cheap scoop to cover up the throttle body and actually mounted it backwards - to help vent the air from the engine compartment into the low pressure area
