Header collection gaskets
+3
7 posters
What kind of header collection gaskets are you all using? I've just had a second one blow out, it almost looks like some kind of compressed paper material (maybe asbestos?).
acorad- Posts : 697
Re: Header collection gaskets
I read on LS1tech.com that the original metal gaskets are better.
I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Once I figured out the centering problem the the steel mesh versions have held up well.
Marc
Marc
marc a- Posts : 170
marc a wrote:I had repeated problems with the gaskets blowing out after trying the white paper looking ones, the steel mesh gray versions and the solid aluminum ones. What I found was the exhaust pipe flange must be centered on the gasket or it will blow a hole in the gasket. You have to slightly tighten the three bolts and use a screwdriver between the flange and the pipe to center.
Marc
Yup! Same thing here except I used alignment weld rings tacked to the pipe side which centered the gasket.
Never saw those before, nice solution!
Thanks, but what is that?
acorad- Posts : 697
That is a ball style collector, The ball goes into the header flange and then you just weld your exhaust pipe onto the end of that.
Also known as Header Buddy / Buddies
acorad wrote:Thanks, but what is that?
