» 944 ls1 swap brakes and transaxle problems.. (Legal in Sweden)
Volvo 20vt? EmptyToday at 5:28 am by gunnarsson
» Diagram for heater lines/vacuum
Volvo 20vt? EmptyThu Oct 17, 2019 5:10 pm by C4924S
» Ford Windsor engine swap
Volvo 20vt? EmptyThu Oct 17, 2019 1:58 pm by Solarflare
» 82 924 with AUX Audi V8.
Volvo 20vt? EmptyWed Oct 16, 2019 1:26 am by Golten1986
Volvo 20vt? EmptyTue Oct 15, 2019 3:01 pm by kevin924kevin
» Sensor compatibility
Volvo 20vt? EmptyMon Oct 14, 2019 8:05 am by gwistrup
» Hood to throttle body clearance
Volvo 20vt? EmptyMon Oct 14, 2019 7:38 am by gwistrup
Volvo 20vt? EmptyMon Oct 14, 2019 7:25 am by Markeric
» 944 with LS3 Clutch Master Firewall Brace
Volvo 20vt? EmptyMon Oct 14, 2019 12:54 am by Worryless
» 86 Porsche 944T LS1 swap begins
Volvo 20vt? EmptyFri Oct 11, 2019 3:57 pm by Midevil1981
October 2019
78910111213
14151617181920
21222324252627
28293031
Volvo 20vt?
Volvo 20vt? Empty Volvo 20vt?
Post  SGoodall on Fri Dec 28, 2012 4:37 am
Thinking of buying a 2.5 944 which needs work, not interested in the 2.5na motor so thinking of suitable swaps possible her in europe. The Volvo 5 cylinder jumps to mind, development work by Porsche, lightweight and happily give 350hp, just thinking about fit currently
SGoodall
Volvo 20vt? Empty Re: Volvo 20vt?
Post  Rich L. on Fri Dec 28, 2012 12:18 pm
There are pictures of a 5 cylinder Audi swap at [You must be registered and logged in to see this link.]
He had to do significant fabrication work; building an accessory bracket, slave adapter and a log type manifold locating the turbo forward of the engine. Looks good and having built an urquattro 20vt track car once upon a time, I bet it sounds awesome.
Post  87-944S on Fri Dec 28, 2012 2:28 pm
Sounds like a cool swap! What year engine?
Post  SGoodall on Sat Dec 29, 2012 4:59 pm
Was thinking the later 2.5 turbos rather than the 2.3 turbos, but I'm not very familiar with volvo engines so need do a little more reading. I know alot more about the Audi 5 in both 10v and 20v and turbo and none turbo, infact I 7 of these engines, one of which is in a ur, and know they will bolt straight to a 924 bell, having used a 924 bell to mount a ford T9 gearbox to a I5 so it would be wise to use one these but I'd like to sink my teeth into a volvo
Already sourced a bell housing so just a car and engine now!
SGoodall
Post  SGoodall on Sat Jan 19, 2013 1:12 pm
So having mulled this over I've acted on this, bought a glacier blue 1989MY 944 2.7 which needs sills, the 2.7 seems to run nice so will stick it up on eBay at some point.
Bought a 2.3 T5 from S70, plan for it is a bigger turbo on the stock manifold with a Focus ST or RS intake with a programmable fuel management system. This should hopefully get between 350 and 400 hp so will be comparable to a LS swap
As for hooking up the torque tube to the T5 I'm going to use a 960 bellhosuing and mill an adapter in work.
I'll get pictures soon
SGoodall
Post  charlie1175 on Mon Oct 21, 2013 10:37 pm
any update on this?
charlie1175
Post  SGoodall on Thu Oct 24, 2013 4:55 am
Progress stalled on this with work commitments, however I have build the engine with steel rods now and have the bellhousing. I measured the bellhosuing bolt pattern on the CMM in work quite a few months ago and have designed the adaptor plate and have plastic templates for mock up but never managed to get it machined yet... Despite having been running a CNC mill for the past 4 months. Hopefully with some time off over christmas I'll get the 20v turbo engine swap in my audi quattro done and will get back on the porsche so keep watching. Next purchase will likely be a holset hx35 which will flow over 400hp of air for me. Opinion is still not settled on the intake manifold as I might go with a custom intake, but I like to have all the parts ready before working on cars in my garage...
On an other note, I have a ur quattro and I love the design the sills on these cars and have been thinking restoring the ones on my 944 to the same style, has anyone seen this done before?
SGoodall
Post  SGoodall on Wed Nov 13, 2013 11:11 am
I have managed to get the adaptor drawn properly last night after staying up to 3am as only time I've had spare latly,
This places the engine upright and will use a Saab/GM clutch release bearing
Few more pictures of the swap and mocking up the engine postion and seeing how much space is avaible for a big turbo...
And a few parts for the build
SGoodall
Post  xschop on Wed Nov 13, 2013 12:14 pm
Are those blocks sleeved or alusil?
Do you think the 2.9 I6 Bellhousing is clocked 12 degrees also. It's factory intake looks like it would interfere with the vacuum booster if put in straight up.
Post  SGoodall on Wed Nov 13, 2013 12:44 pm
The bores are cast in iron liners, the earlier 2.3 engines like this have thicker liners is why I've chosen it
I measured the tilt from the top two holes that are level on the engine against the ones on the back.
[img][You must be registered and logged in to see this image.][/img]
For the intake manifold I'm planning to delete the booster and look to move to the other side as I'm in the uk and the car is right hand drive. But I'm going to make a a new plenum to remove the variable length intake
SGoodall
Post  xschop on Wed Nov 13, 2013 2:17 pm
Thanks for the pic. I bet that would clear the 944 booster.
Post  dbailey1234 on Sun Dec 08, 2013 1:37 pm
I would like to learn more about this swap as I have a volvo engine available to do it. IF someone could make that BH adapter, I could fabricate all of the other parts needed. Intake, headers, mounts, etc. Thanks,
David Bailey
Idk if you are able to PM me or not since I'm new...Should be in the next couple days if not.
will post email when i can.
dbailey1234
Post  xschop on Mon Dec 09, 2013 11:35 am
If your Bellhousing looks like the trans interface hole in Sgoodall's pic, I have the adapter already made. You'll have to figure out the Flywheel and clutch, but that's easy.
Post  SGoodall on Sat Mar 08, 2014 2:37 am
Machined my adaptor finally and bolted it in last night with a bare block
SGoodall
Post  daveslp on Sat Jun 03, 2017 7:32 pm
Any update on this?
daveslp
Post  daveslp on Sat Jun 03, 2017 7:34 pm
I'm not overly impressed with the power of my 944s 16v and I'm enthrawled by my buddy's Focus ST with a stainless system!
I also know of a 240bhp engine from a s70, 70k miles and fully complete.
Would love to know more details of this swap.
Will it clear the bonnet?
daveslp
Volvo 20vt? Empty Updates?
Post  ChrisCO on Mon Sep 30, 2019 10:56 am
Love it, have considered this engine myself- turbo 5 cyl engines do make some of the best noise..
Any updates?
ChrisCO
