Today at 8:39 am by chrenan
» Tpc LS adapter plate
» Headers, headers, HEADERS!
oil pans and uprights
Post  kevin924kevin on Tue Dec 25, 2012 12:09 pm
Just wondering if we use these uprights and oil pans to allow everything to stay under the hood. or is there another reason, being that i am going to have a power bulge, hieght is not an issue. Just wondering. Any thoughts would be appreciated.
Re: oil pans and uprights
Post  Admin on Tue Dec 25, 2012 4:05 pm
WE use them mainly for hood clearance. The other reason is the strength. If you are thinking of using the old style mounts be aware that the rubber type tend to come apart.
Post  kevin924kevin on Wed Dec 26, 2012 8:44 am
Admin, i intend to use yours, but question,i have the steel cross member.(1978 924 ) My mounting points for my manual rack are closer together than that of the aluminum cross member, is this going to be an issue.Is the new oil pan tappered on both sides. I believe the alum cross member has about 9" between the mounting points where i have around 7" beteween mine. I will do a measure to confirm. Any thoughts or suggestions much appreciated.
Measurements
Post  kevin924kevin on Thu Dec 27, 2012 9:01 am
I took a close look and the steel cross member mounts for the rack are closer together. They are also farther away from where the control arm bolt holes on the steel than the aluminum. My concern is the pan, for the clearance issue as i see on this form.Can the pan be trimed more inwards to allow for proper clearance, or do i need taller mounts.Any input would be greatly appreciated. As i am in the process of my motor being shipped i need to solve this issue.
Post  Rich L. on Thu Dec 27, 2012 12:34 pm
Even with the aluminum crossmember I had to do a bunch of trimming to get things to fit without contact. This with TPC's oil pan, uprights and headers. I didn't like removing as much material as I did but haven't noticed any issues. I plan to pull it and check for cracks this winter.
And yes, narrower mounting points for the rack will be trouble. My suggestion would be to get the Moroso pan and make your own modifications to suit your car.
Post  kevin924kevin on Thu Dec 27, 2012 12:51 pm
Thank you for your response, i think this may be the way i have to go.
Post  Admin on Thu Dec 27, 2012 7:30 pm
My new style oil pan does not require any trimming of the cross member. It is built as close as possible to the pickup tube and windage tray. No it can not be moved or trimmed any further that what I make them now. Also the new headers do not require any cutting of anything major to make them fit either. I have worked hard to make sure there are no more trimming issues. I know people do not like to do that. The parts that have needed to be trimmed in the past were areas of no structural importants. As far as the up rights and pan fitting the 924 cross member, I have not gotten any feed back from the two sets that I have sold for installation into a 924. I will work with you on getting something to work. Is your car appart enough that you can send me the cross member? If so I can build a setup around it so we know it will work. I have a mock up motor and a car that I use ( 944 of course) for test fitting during the build and right before shipping as well.
Post  Rich L. on Fri Dec 28, 2012 12:40 am
Glad to hear you've made some adjustments, Eric. Cheers!
Post  Admin on Fri Dec 28, 2012 1:08 pm
Constant evolution in this business......... Shocked
Post  zeusrotty on Sat Dec 29, 2012 1:34 am
Eric, do I have the newest version of the uprights and pan? I bought them in the summer.
zeusrotty
Post  kevin924kevin on Sat Dec 29, 2012 3:15 pm
Eric, i think i will wait for my motor, and check before i pull my cross member. I just ordered your new up rights.Once i can hang with the new mounts i will c what will have to happen. After doing a closer look, i think i will have the room. My steel member offers more space than the aluminum one. Now just need my motor to land and your mounts. Thank you will be in touch.
manual rack
Post  kevin924kevin on Sat Dec 29, 2012 3:19 pm
Could someone post a picture showing the drivers side rack location to the pan and block. I would prefer a manual stystem but any photos of this would help. Thank you.
Post  Rich L. on Thu Jan 03, 2013 9:25 am
There are a few good shots in this thread:
Hope that helps.
clearance
Post  kevin924kevin on Thu Jan 03, 2013 2:00 pm
Rich, thank you for the pics they are really helpful.
Post  Tim on Fri May 10, 2013 9:40 am
Admin wrote:My new style oil pan does not require any trimming of the cross member. It is built as close as possible to the pickup tube and windage tray. No it can not be moved or trimmed any further that what I make them now. Also the new headers do not require any cutting of anything major to make them fit either. I have worked hard to make sure there are no more trimming issues. I know people do not like to do that. The parts that have needed to be trimmed in the past were areas of no structural importants. As far as the up rights and pan fitting the 924 cross member, I have not gotten any feed back from the two sets that I have sold for installation into a 924. I will work with you on getting something to work. Is your car appart enough that you can send me the cross member? If so I can build a setup around it so we know it will work. I have a mock up motor and a car that I use ( 944 of course) for test fitting during the build and right before shipping as well.
I have to grind some of the crossmember to make it fit. That, or space it even further.
Tim
http://www.OEMPartHaus.com
Post  Admin on Fri May 10, 2013 10:26 am
Depending on the exact pan you have , you may have to trim/grind a little off the cross member.
Post  Tim on Sat May 11, 2013 10:43 pm
I have your new style oil pan.
Tim
