Clutch Slave Banjo Bolt--From RH kit
Does anyone know the particular clutch slave that came in the original RH kits. I need the Banjo Bolt. Went to NAAPA and they couldn't find any SAE or metric banjo or regular bolt that would thread in. If I can find the model of the car it came from I might be able to get a banjo bolt. If you know the size and pitch of the threads on the banjo bolt, that would probably work.
944-v8- Posts : 59
Re: Clutch Slave Banjo Bolt--From RH kit
For the LT engines, the clutch slave they supplied in the kit was from a 1988 Corvette.
Thanks Lt1
944-v8- Posts : 59
» Xschop's 5.3 LM7 build
» Banjo Fittings for Wilwood MC
» Selling off my stock clutch parts and RH clutch disc
