» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
944 Driveline Question
Post  jmking on Mon Dec 03, 2012 2:57 pm
I'm new at the swap thing but I was just wondering how big can a drive shaft for the 944 be without having to fab the tunnel? Thanks!
jmking
jmking
Re: 944 Driveline Question
Post  Admin on Mon Dec 03, 2012 3:50 pm
What are you referring to?
The 944 has a torque tube and the trans is in the rear.....
Are you installing a straight axle in the rear? If so you will need to reconstruct the fire wall area around the bell housing of your transmission. Manual transmission will only need a little bit of messaging but if you plan to install an auto you'll be in for a lot of fab work.
As far a drive shaft, you can fit just about any standard size drive shaft in there (3" and 4" are most common dia.)
