» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Starter motor for use with LT1
Post  quarterflash on Fri Nov 30, 2012 4:12 am
Hi
Can anyone recommend a starter motor for use with the LT1 / 951 conversions? Can I use the standard corvette motor? The engine is from a '95 Corvette
Thanx
Q
quarterflash
http://porschevy.co.uk/
Re: Starter motor for use with LT1
Post  Admin on Fri Nov 30, 2012 8:12 am
Stock starter should work just fine
body clearance and clutch
Post  quarterflash on Fri Nov 30, 2012 8:29 am
Hi
Thanks Admin, Will it clear the body ok?
Also I will be using a 10.5" clutch as supplied by RH. Am I correct in getting a standard cast 153 tooth flywheel and a clutch cover/presssure plate with a diaphragm rated at 2400 pounds?
Thanx
Q
quarterflash
