Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
IFC Widebody Kit - WARNING! Parental discretion advised
Page 4 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: IFC Widebody Kit - WARNING! Parental discretion advised
Post  skywalker01 on Fri Sep 25, 2009 7:30 pm
....and this response is coming from a guy who can fabricate anything?? You'd think drilling some holes in angle iron would be a snap Suspect
skywalker01
Post  skywalker01 on Sun Oct 04, 2009 3:31 pm
Well after several weeks of distractions, I finally got to spend some time on the body kit. I ended up cutting the bumper cover off becuase the license plate 'dent' was hitting the bumper. No matter what I did, I could not get the bumper cover to fit properly so I ended up installing the kit without the bumper. I curse the person who rearends me! But the kit looks beautiful. Now I have to work on the nose!!
skywalker01
Post  skywalker01 on Sat Oct 24, 2009 6:52 pm
Update - slowly working on the front of the car. Got the 944 Carerra header panel, but I guess Porsche no longer makes the screens for the porrts. Came up with my own solution by placing an order to McMaster-Carr and picked up some perforated metal and bonded it to the header panel.
Guess the trick to making this look good is aligning the pattern. I plan on painting them flat black.
Test fitting of the hood - nice to know that I got it right the first time!! Will have to re-run the MAF wiring. It's preventing the hood from coming down fully. Believe it or not, this is the first time the hood has been on the car since the removal of the Porsche engine.
I am currently waiting on fog lamps - they should be in on Monday. That's when I go to work on the front spoiler.
skywalker01
Post  RobotMachines on Sat Oct 24, 2009 8:23 pm
Hot damn... looks like it will look very good when painted or even primed!
You have it running?
P.S. I like the way you made the rear bumper area look; very modern.
RobotMachines
Post  skywalker01 on Sat Oct 24, 2009 8:49 pm
RobotMachines wrote:Hot damn... looks like it will look very good when painted or even primed!
I 'had' it painted - that was until the widebody bug bit me. Oh yeah it runs!! I was hoping to have it on the road before the end of summer, then I got distracted. I'm glad I got the kit - I can now run the 12" rims in the rear like I always dreamed of. I am currently waiting on a replacement hatch like this one - the GT-Racing one that I have now sucks! The IFC Racing one has hinges and all of the fittings that will allow me to basically just screw it on. (unlike the GT_Racing one)
This will finish off the rear. I am really looking forward to getting the foglights so I can get to work on the front spoiler. Thanks for the compliment - recognition from the 'old crew', such as yourself, makes all of this worthwhile.
skywalker01
Post  87-944S on Sat Oct 24, 2009 11:14 pm
I need to stop by again and see it in person, the pictures don't do the hard work justice!
Post  skywalker01 on Sun Oct 25, 2009 7:01 am
Thanks Mike! I just wish it didn't take so much darned time! You're not authorized unless you bring your laptop so we can mess with the PCM some!! Very Happy
skywalker01
Post  m73m95 on Sun Oct 25, 2009 10:16 am
its coming along very nicely!
m73m95
Thanks Luke
Post  xschop on Sun Oct 25, 2009 11:27 am
Big Thanks to Skywalker. Those pics of the brackets did the trick. I machined a solid steel bracket to bumper dimension 2.375" out from the 944 body. This put the edge of the rear bumper out exactly 1" after install. This changes the look of the rear nicely and that aftermarket rear bumper cover fits right on......
Post  skywalker01 on Sun Oct 25, 2009 11:50 am
See?? I knew a big time machinist such as yourself could figure something out from a couple blurry shots of a part laying on a ruler! Laughing Great job!! Those work for the front too!! One thing though - if the bumper cover has a license plate indentation (like mine), there is still not going to be enough clearance with the Porsche bumper.
skywalker01
SMS
Post  xschop on Sun Oct 25, 2009 12:08 pm
My SMS certificate really did pay off this time lol!
Post  gt1scca on Sun Oct 25, 2009 1:51 pm
xschop wrote:My SMS certificate really did pay off this time...
Now you know that was baiting me...
Razz
Get the mounting position for the late 944S, and you could use the factory end caps. S rear bumper is close to the same distance, using SMS of course...
placing my order...
Post  968gene on Sun Oct 25, 2009 9:38 pm
OK, my track car will need a set of these....can I then shave and inch from the top and bottom of the bumper? I'd like to toss the extra weight from the bumper shocks.
Gene
xschop wrote:Big Thanks to Skywalker. Those pics of the brackets did the trick. I machined a solid steel bracket to bumper dimension 2.375" out from the 944 body. This put the edge of the rear bumper out exactly 1" after install. This changes the look of the rear nicely and that aftermarket rear bumper cover fits right on......
968gene
Post  skywalker01 on Mon Oct 26, 2009 4:48 am
968gene wrote:OK, my track car will need a set of these....can I then shave and inch from the top and bottom of the bumper? I'd like to toss the extra weight from the bumper shocks.
Gene
It's more to bring the bumper in closer to the body, than changing the height (if I understand your question correctly) - and yes, you'll shave weight from the shocks. Just don't bump into anything!!
skywalker01
-10 points
Post  968gene on Mon Oct 26, 2009 6:25 am
Gene
Sky, i meant from the leading edges.
968gene
Post  Admin on Mon Oct 26, 2009 7:29 pm
The fiber glass euro bumper that I am coping fits tight to the rear of the car without all the extra work, and the rear bumper has 2 fiber glass 90* brackets that save the extra weight. Again you would not want to be hit or hit anyone with it, because there is no crash protection there.
Post  skywalker01 on Mon Oct 26, 2009 7:40 pm
Foglights came in. These are the 85mm Hella units I picked up from buyautotruckaccessories.com for a paltry $37.95 a piece (vs. $50 and up at other places)
I am planning on mounting these in the front spoiler - two on each side.
skywalker01
Post  RobotMachines on Mon Oct 26, 2009 9:21 pm
I just don't think two on each side will be enough Very Happy
RobotMachines
Post  skywalker01 on Tue Oct 27, 2009 5:00 am
RobotMachines wrote:I just don't think two on each side will be enough Very Happy
This is coming from a guy with a sig of "Twice the horsepower, twice the fun"? Laughing
I just want to be able to see deer in the next county before they run out and try
to commit suicide on my non-steel fontend. Besides - thats a lot of empty space
up there to fill, and I wanted a different look.
skywalker01
Post  944-LT1 on Tue Oct 27, 2009 4:02 pm
Laughing Laughing Laughing
Post  RobotMachines on Tue Oct 27, 2009 8:54 pm
Wait a second skywalker01 (little off topic), what wheels do you have on your 948? Those rear wheels look wide and pretty good (just watched your video of your -around the block- run)?
P.S. Like the yellow hose... you need some yellow zip-ties as well. Very Happy
RobotMachines
Post  944-LT1 on Tue Oct 27, 2009 10:21 pm
....Oh YEAH....Sky's got yellow thingy's all over that car. Laughing
Post  skywalker01 on Wed Oct 28, 2009 5:05 am
RobotMachines wrote:Wait a second skywalker01 (little off topic), what wheels do you have on your 948? Those rear wheels look wide and pretty good (just watched your video of your -around the block- run)?
I did that just for you guys Very Happy The wheels that you see are the stock cookie-cutters. I have 2"
spacers on the rear. Will probably take the plunge and go with 11x17 in the rear and 9.5x17 in the front. I think I'll need it to fill the fender wells
skywalker01
Post  skywalker01 on Wed Oct 28, 2009 5:07 am
944-LT1 wrote:....Oh YEAH....Sky's got yellow thingy's all over that car. Laughing
It's called 'color coordination'!
skywalker01
Post  944-LT1 on Wed Oct 28, 2009 5:42 am
This reminds me of skywalker..... [You must be registered and logged in to see this image.].....I dont know why.....everytime I see it, I think, if it were hammers in his hands and a 944 instead of drums.............skywalker.
JK sky. Laughing
