» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Cold air intake
Cold air intake
Post  ynbad on Mon Nov 19, 2012 7:13 pm
Anyone have a idea of cold air intake plumbing. I like some of the corvette set up but not sure they will clear the radiator and condensor since they stand straight up instead of leaning back like the vette and camero.
ynbad
Re: Cold air intake
Post  rpwach on Thu Nov 29, 2012 10:42 pm
Some people have tilted the 928's radiator back to give more room. If you are fitting a different radiator, you can install one that is not as tall (19in) as the original radiator.
On my own car I've move the air filter to inside the right fender where the windshield washer water was. That also requires moving the coolant expansion tank, and there probably are better ways.
rpwach
