» Transaxle rebuild
» Tpc LS adapter plate
Anyone else have a leaky H-valve?
Post  Arthropraxis on Sun Nov 18, 2012 8:00 pm
I have but two heater H-valves in and they both have leaked the metal plunger. Both have been new units, is there a brand that is better than another?
Re: Anyone else have a leaky H-valve?
Post  87-944S on Mon Nov 19, 2012 11:14 am
Just curious, where is it mounted? I don't have any street time on mine, but I paid too much from RH many years ago. No idea of brand, probably a cheap copy of the GM piece.
Post  Arthropraxis on Mon Nov 19, 2012 6:15 pm
It is in the same place as the others that I see. Up front as far away as it can get from the headers. It doesn't seem to be a heat issue. It drips intermittently with the heater off and stops with the heater on. No way to tell if it leaks while I am driving. Not a big deal but it is annoying.
Post  87-944S on Mon Nov 19, 2012 8:29 pm
That would drive me nuts! I was asking about location since I am redoing my heater hoses, wanted to see what you did. Smile
Post  Arthropraxis on Sun Nov 25, 2012 8:28 pm
These valves aren't unidirectional, are they?
Post  87-944S on Sun Nov 25, 2012 9:00 pm
I don't know if they are or not, but take a look at this valve (also at Rock Auto for $38)
Not sure if the metal construction would make it less prone to leak, but thought I throw it out there.
Post  Arthropraxis on Mon Nov 26, 2012 6:48 am
Thanks, I may try that one. I looked at an AC delco part and it looked exactly like the one on my car, probably the same part renamed.
Post  87-944S on Tue Nov 27, 2012 8:32 pm
I ordered one to take a look at, it is directional and seems to be well made, and has what looks like a nylon ball valve. I'll keep it and use it.
Post  acorad on Wed Nov 28, 2012 1:35 pm
I just noticed this AM that I'm having the same problem, except it's a lot more than intermittent with the heater off!
Also, as of all of a sudden last night, I can't regulate the heat when it's on - regardless of how I turn the heater control knob on the dash, the heat is on lava-hot.
I think my H-valve is dead. Which is weird because it's basically brand-new, I replaced it less than a year ago when the previous one cracked and fell apart...
Post  Arthropraxis on Wed Nov 28, 2012 5:14 pm
Acorad, check all of your vacuum connections. I had one fall out and it makes the valve fail in the open position.
Post  acorad on Thu Nov 29, 2012 11:35 am
Thanks Anthro, turns out it's the infamous plastic heater clip under the driver's dash. [You must be registered and logged in to see this link.]
Post  docwyte on Thu Nov 29, 2012 3:00 pm
Ya know, I bet that clip is broken on my car too. I'll have to check it out tomorrow...
Post  Arthropraxis on Thu Nov 29, 2012 6:14 pm
My car has some temp sensor bad on the passenger side under the glovebox. I can hear a click then the heat comes on even if it is off. It will click again and go off. It intermittently cycles back and forth or I can manually turn the knob full hot then back to off and it clicks off. Completely separate issue than the leaking H-valve which now is more that just dripping.
Post  Arthropraxis on Sat Dec 15, 2012 7:13 pm
If anyone else has this issue with the leak, I may have found a fix. I removed the vacuum diaphragm, washer and o-ring under it. I filled the hole with gasket maker, put the o-ring back in with the washer on top, added a washer from another h-valve for compression and reinstalled the vacuum diaphragm. It hasn't leaked in a week. It probably will now that i said that.
Post  87-944S on Sat Dec 15, 2012 7:30 pm
For that clicking noise, there is a known problem with a plastic or nylon breaking in the heater assembly that makes a click, not sure if that is your problem or not. Saw a few articles on a fix in Excellence or some other mag a few years ago.
Post  Techno Duck on Sat Dec 15, 2012 8:08 pm
That click i believe is the solenoid for the automatic climate control. My n/a used to go bezerk clicking sometimes on cool nights with the heat set to max, if i turned it just before the max setting it would be fine.
Post  Arthropraxis on Sat Dec 15, 2012 8:16 pm
The heater clips are all intact, as far as I could find. The fan that sucks the air from the grill in the dash next to the clock is dead or dying. At times it sounds like a tree frog chirping in my dash.
Metal Heater Valve
Post  fliermike45 on Tue Jul 02, 2013 10:09 am
I finally got rid of the leaking plastic heater valve and installed a Autotemp H4956 metal heater valve.
Post  acorad on Tue Jul 02, 2013 12:57 pm
Very nice. My plastic one broke in half on the way to work one day. The metal ones are the way to go.
Post  87-944S on Tue Jul 02, 2013 9:26 pm
Here is where I put my metal valve, the heater hoses run through the wheel well and exit on the other side of the shock tower. I used aluminum tubing for the runs in the wheel well.
Post  Diyman25 on Wed Jul 17, 2013 1:14 am
I too have broken heater valve
i found out because i no longer have cold AC !!!!! in my area the temp never drop below 60
so AC is the one you need the most !!
and the valve was stuck open cause the heater and AC to be turn on at same time
what a nighmere when u stuck in 100F traffic jam
right now i will try to bypass the valve for now
and waitting for metal that i seen in this thread
J
Diyman25
Post  spence on Wed Jul 17, 2013 4:19 am
I bet the plastic clip inside the cabin, under the drivers side console is broken causing the valve to be wide open. This will cause both the A/C and heat to be on at the same time.
Post  Diyman25 on Mon Jul 22, 2013 3:26 am
spence wrote:I bet the plastic clip inside the cabin, under the drivers side console is broken causing the valve to be wide open. This will cause both the A/C and heat to be on at the same time.
thanks for reply
i already by pass the heater now... dont really need it in my area
but will try to fix that as my next to do list Smile
Diyman25
