Suspension and roll cage
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Tracking Your Car
Hi all,
Wondering what track car owners are running as far as suspension with the V8 (coilovers, rear torsion bars delete, spring rates, bushings, etc.).
Also, anyone using prefab roll cages ? (Autopower, Safety devices or other)
Thanks much.
Marc
Thanks much.
Marc
Marc948GTR- Posts : 27
Re: Suspension and roll cage
I don't have either, but the answer to your question is going to be the same as with the stock engine. The v8 doesn't add any weight!
cages
A nice prefab weld in place cage, call Hank at Hanksville hot rods. He specilizes in 944 cages. I purchased my unit from Hank. He also did my custom cross member for the rear to allow my C6 6speed trans. He also gives a discount for the 944 owners.
Last edited by kevin924kevin on Thu Nov 08, 2012 2:10 pm; edited 1 time in total (Reason for editing : update)
kevin924kevin- Posts : 927
I live locally to Hank, he did the custom rollbar in my 948. He does great work!
I had 944 Turbo S suspension with M030 968 swaybars, higher rate front springs and 30mm torsion bars. It worked pretty well. I'm actually going to have it for sale (well, not the swaybars, I'm keeping those) as I'm about to do a torsion bar delete and go with Bilstein Escort Cup coilovers.
Thanks everyone for your comments, noted.
Hanksville roll cage looks like the best bet with all the available options.
Is it as tight fitting as the pictures shows ?
Does anyone have the extended "Nascar style" door bars ?
Modified doors or figerglass unit used ?
I also like the Bilstein coilover setup, with the torsion bars deleted.
Doc - What spring rates are you looking at with the Bilstein setup ?
See ya !
See ya !
Hanks cage is meant for a gutted car, so bear that in mind!
I'll start with 450# front, 700# rear spring rates and tweak from there...
cage
Hank builds the cages for cars with or without interiors, they build to meet your needs. My car will have some of the stock interior in place,it fits perfect.
Yes, he does have them for cars with interiors, didn't know he had a "kit" for 944's with interiors though...
subframe connectors
I have often thought about just reinforcing the subframe connectors and basic rollbar instead of full roll cage.
I have the rolbar, any thoughts on subframe connectors?
My rollbar is welded into the rear subframe and rear frame rails.
