Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
help with codes p0171 & p0174
Post  948inVA on Sun Nov 04, 2012 4:06 pm
My ECM is throwing these codes - p0171 & p0174 which indicate a lean a/f mixture on both banks. Anyone have any ideas what it could be? I'm wondering if my fuel pump isn't putting out enough pressure, or I need to have the injectors cleaned. The engine idles and runs fine..
948inVA
Re: help with codes p0171 & p0174
Post  Pataforce8 on Sun Nov 04, 2012 4:22 pm
Could be a leak in the intake tract after the MAF sensor.
Pataforce8
Post  Arthropraxis on Sun Nov 04, 2012 5:08 pm
Squirt some brake cleaner around the intake, pcv hoses and vacuum ports to see if you have any gasket leaks and tighten up your header bolts . I did this and found leaks, sealed them up better with hose clamps and new intake gaskets. The car ran much better with a decrease in an annoying vibration around 3K RPMs.
Post  zeusrotty on Mon Nov 05, 2012 2:23 pm
Arthropraxis wrote:Squirt some brake cleaner around the intake, pcv hoses and vacuum ports to see if you have any gasket leaks and tighten up your header bolts . I did this and found leaks, sealed them up better with hose clamps and new intake gaskets. The car ran much better with a decrease in an annoying vibration around 3K RPMs.
Check vac hoses everywhere. Throttle body, manifold, etc.
zeusrotty
Post  948inVA on Mon Nov 05, 2012 3:11 pm
Thanks for the ideas.. maybe I forgot to tighten a hose clamp somewhere. Hopefully it's something simple like that.
948inVA
Post  944convert on Mon Nov 05, 2012 3:45 pm
Be careful spraying anything flammable around a running engine.
One errant spark can ruin your day.
Make sure you have something close at hand to put out a fire...jus' sayin'
Post  Arthropraxis on Mon Nov 05, 2012 6:02 pm
The PCV hoses themselves get old and crack.
Post  acorad on Tue Nov 06, 2012 12:41 pm
I got those codes recently and I had a loose hose clamp just behind my MAF.
Post  948inVA on Tue Nov 06, 2012 2:01 pm
Think I found the culprit.. my fuel hose between the tank and pump had cracked and I had done a quick fix with some regular fuel hose and a curved hard line stuffed inside. Forgot to replace it with the oem hose when it came in and it must have been causing a restriction!
948inVA
Post  948inVA on Tue Nov 20, 2012 6:19 pm
Well I'm still getting the same codes. I've sprayed carb cleaner around all the vacuum connections with no effect. Anything else I should check?
948inVA
