correcting front ride height after swap
What is everyone doing to bring the front of the car back to stock ride height? It seems to be about 1/2" higher now in the front.
948inVA- Posts : 224
Re: correcting front ride height after swap
I used this [You must be registered and logged in to see this link.] to set the ride height. I also have the paragon kit to convert the front struts to coilovers, makes it easier to adjust the ride height.
I'm using bilstein inserts with early strut housings, so they're not adjustable. I think I'll just order some of the weltmeister lowering springs and see how it looks, maybe I can add a spacer if it ends up too low.
