Today at 12:03 pm by superman22x
» ecotec swap
Yesterday at 8:41 pm by sharkey
» 86` 944 turbo project
Yesterday at 6:33 pm by 948
Yesterday at 6:27 pm by 948
» LS3 Exhaust
Yesterday at 4:29 pm by Hotrodz of Dallas
» alignment specs
Yesterday at 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Yesterday at 2:03 pm by superman22x
» Question about 964 transmission into 924s/944
Thu Jan 18, 2018 1:52 pm by Hamr20
Thu Jan 18, 2018 12:36 pm by sharkey
» For sale $150 Griffin for LS1 LS Radiator swap
Thu Jan 18, 2018 12:33 am by jshprd
January 2018
AN-6 fitting on Rack Power Steering Input.
Post  grobb284 on Sun Oct 14, 2012 2:18 pm
I have been plumbing my Hydroboost of late, and working toward the 944 power rack.
I have converted the LS1 power steering pump to output AN-6.
The input of the hydroboost is adapted to AN-6, and the hydroboost pass through for the power steering to AN-6
My question is the power input to the rack. I can convert the 12mm x 1.5 adapter directly to either AN-4 or AN-6.
If I use AN-6, all my hose stays the same size on the power sides, which is a plus, as I have the Parker 919 stainless -6 hose and no additional fittings needed.
If I use AN-4, I need to make an AN-4 hose, and adapt it to the AN-6 hose output of the hydroboost, which will invole a reducing coupling and 2 more fittings to leak.
I like the idea of the an-6 as direct input to the power rack. However, will this add to the problem of the overcapaity of the LS1 pump to the Porsche rack, as there is no restriction?
Has anyone done this using all AN-6 to the power rack with the stock LS1 pump, any problems with overcapacity or twiching? I do not plan autocrossing, so I'm not thinking it will overheat, so I'm not modifying the pumpat this time
I also have a question on the O-ring style adapters on the Hydroboost. How much do you tighten against the adapter tube style O-ring? This is not a Ford unit, but a GM truck style.
grobb284
Re: AN-6 fitting on Rack Power Steering Input.
Post  Admin on Mon Oct 15, 2012 7:52 am
I use a #6 fitting there all the time without any problems
Post  87-944S on Mon Oct 15, 2012 3:20 pm
Same here all -6AN for the pressure side of things.
Post  grobb284 on Sat Oct 20, 2012 11:29 am
Thanks for responding, will do the same.
grobb284
