1986 944 TURBO 5.3 L33 CONVERSION
+4
Tim
LEEEZARD7
8 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: 1986 944 TURBO 5.3 L33 CONVERSION
although it is possible to press the old suspension bushings out of front arms and rear trailing arms, you would have to build special fixtures to do it without hurting the arms. odd angles. anyhow i gently melted the old bushings out tonight. bottom of car is clean and wire wheeled, ready for paint.
ps 100ton electric over hydraulic press. so i had ooomph behind it, just afraid i was going to break or bend an arm.
LEEEZARD7- Posts : 148
new timken front inner and outer wheel bearings with new seals on the way. new timken rear wheel bearings, new kyb front strut inserts, on the way. rally car billet nitrogen adjustable coilovers on the way for the rear shocks. when im done it will be a totally new/rebuilt car mechanically. budget has changed at this point. i will be in the 5500.00 to 6000.00 range. still budget minded overall tho.
still will be only half the cost of my buddies c5 vette and i will have a far nicer and more capable car.
his vette is a stock 1998 c5 coupe, stock rubber suspension bushings, stock struts, stock brakes, stock ls1. my car will be L33 with around 400rwhp, poly bushings, new struts with coilover conversion, new rally coilovers in the rear, boxster brembos, etc etc etc... will be fun when amatuer track day rolls around... lol. last summer i drove his vette at the local track and was 3 seconds faster than him in his own car... lol. thats when he popped off and said "if you only had a porsche that was as capable as my vette and didnt cost 100grand..." thus the purpose of this entire build.
EDIT; i also have another friend with a 1995 c4 vette that he also road races, but he likes 944's.
ok acid stripped several areas under the car. ready for the rustoleum chassis black paint. already cleaned the front and rear factory aluminum suspension arms, and front crossmember. pressed in the new prothane poly red's. tomorrow will be rebuilding the front struts with new vht paint and new inserts. h&r springs front and rear. building new cromoly heim adjustable links for the front and rear sways with kevlar/teflon inserts. new prothane poly reds for both front and rear sway mount pads.
goal is by the end of the wkend have engine compartment cleaned and painted and setting the motor in permenantly early next wk. have test fit the motor and aluminum truck pan several times now.
OK... anyone out there have the oem factory aluminum 5spd transaxle mount. the one that bolts to the top of the gearbox itself? i need one. thanks, mike in oklahoma
the crossmember is cleaned and ready to redrill the arm mount holes .750 inch upward. the arms front and back are clean and ready for fronts to be modded with the early balljoints. poly's are all installed. bottom of car is clean and entire bottom of car will likely be black by end of night.
Man, you are moving quick, want to come and finish mine? Seriously though, progress is impressive!
THANK YOU. i appreciate the compliments. my goal is i want the car driveable by mid january. then paint and minor details on interior at that point. short term goal is all new chassis/poly red mods and suspension/coilovers mods, brake/brembos mods, tires/wheels and rolling by christmas. and of coarse it will be show car clean and detailed as well. not that it will be a show car... lol.
k back from holidays. will resume work on car in the next day or two.
Didnt get the car rolling before christmas as planned but hopefully should be in the next few days. then back to schedule.
ok... my daughter told me today she wants a 911 carrera instead of the 944. the 944 is her car. of coarse, daddy said yes dear.
ok the verdict is in... 911 carrera it is. wont be getting rid of the 44 but wont be doing much work on it for a while either. thanks all for your kind words and support.
» Tilton Dual MC Setup
» 1986 944 na with turbo 5.3 for sale
» 1986 944 turbo / 951 near Pittsburgh PA
Page 3 of 3
Today at 9:56 am by ndog52
