» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
1986 944 TURBO 5.3 L33 CONVERSION
Page 1 of 3 1, 2, 3  Next
Post  LEEEZARD7 on Tue Oct 09, 2012 11:51 pm
1986 944 turbo 5.3 l33 conversion. this is a low budget build on purpose. yes the economy, yes times are slow in my business, but i want to prove a point moreover. build a nice 944 turbo ls5.3 car that is reliable, quick, and far cheaper than my buddies 1998 corvette c5 he has 14g in. my budget is 5-6 grand. the car was free, the 5.3 aluminum L33, 243 heads cnc ported, patriot camshaft .590lift .242dur and titanium retainers and dual springs good to .700lift, gmpp 1.8 full roller rockers 1600.00. arp 8740 head stud kit, arp 8740 main stud kit, arp 8740 rod bolts, arp cam bolts, arp flywheel bolts, arp clutch bolts, arp 8740 entire bolt kit for entire motor. copper head gaskets so i can shoot juice in it if i choose. stand alone harness/custom tune pcm 470.00. 78MM gm ported throttle body, 78mm gm ported maf, jbl stainless truck headers to cut and modify. 14" stainless magnaflow muffler. ls6 intake with fuel rails and injectors. OEM BOXSTER S 17" twist wheels with michelin pilots 1200.00. c5 2pc bellhousing 75.00. c5 flywheel/pressure plate 75.00 off ebay shipped. mopar new 11" clutch disc sent to clutch shop and had kevlar installed 155.00. oem new c5 clutch slave/tob 140.00. made my own c5 to 944tt adapter on my bridgeport 35.00. motor mount setup 175.00 shipped. 4 boxster "s" brembo calipers 400.00. Cross drilled rotors. stainless steel brake hoses 65.00. mustang gt hydroboost and master cylinder 70.00 shipped. ls1 gear reduction starter 3hp 85.00 shipped. gm oem vss sensor and vss gear and bracket. new moog early ball joints, 40.00 shipped. drop the crossmember 1.0 inch, raise the motor mounts .500 inch, redrill the arm mounts in the crossmember .750 inch up, relocate early balljoint 1.0 inch up on arm to offset the 1.0 inch drop, drop rear of front control arm .250. lm7 aluminum truck oil pan. new timken front and rear wheel bearings and seals. new kyb front strut inserts with coilover conversion and poly tops. real rally car billet adjustable rear nitrogen coilovers. xschops billet/poly trans mount, hydroboost mount. prothane custom poly red kit for entire car suspension bushings. next will be a 951 gearbox with na 5th.
so far at the moment i have aprox @ $4500.00 in the car at the moment. there will be more. so here we go...
EDITED FOR UPDATES... GOAL IS 400RWHP... VERY DOABLE!
LEEEZARD7
Re: 1986 944 TURBO 5.3 L33 CONVERSION
Post  LEEEZARD7 on Wed Oct 10, 2012 12:04 am
the only planned body mods are... front splitter, 968 mirrors, and 924gts front nose panel with vents.
EDITED: have all pieces now 11/25/2012
LEEEZARD7
Post  Admin on Wed Oct 10, 2012 8:03 am
That sounds like a lot of spacing on the cross member...... Shocked Not sure you will ever be able to get the steering correct again!
While go through all the trouble, just modify the oil pan, way easier. and won't look so dis proportional .
Post  LEEEZARD7 on Wed Oct 10, 2012 1:33 pm
ADMIN, HOW MUCH IS YOUR PAN?
LEEEZARD7
Post  xschop on Wed Oct 10, 2012 5:31 pm
$5k swap is definitely doable with the 5.3 as long as you have the car already...Very Happy
Post  LEEEZARD7 on Wed Oct 10, 2012 7:22 pm
ROB, it is the l33 5.3. which is an aluminum block 5.3 with flat top pistons, 243 vette heads, and it has a ls2/ls6 cam already with springs and valves to match. should make a reliable 350hp at the rear wheels and be fun and spirited to boot.
LEEEZARD7
Post  LEEEZARD7 on Thu Oct 11, 2012 10:25 pm
motor mounts showed up today. didnt feel like fabbing them from scratch with everything else i have going on right now. likely same will happen with pan. rob i saw in one of your posts where you redrilled the crossmember a arm bolt locations. how did that work out for you? did you like the end result?
LEEEZARD7
Post  LEEEZARD7 on Sat Nov 10, 2012 7:00 pm
had a good meeting with a 944v8 forum member. removed the hood, and gonna get trans #2 out and cleaned up for install.
LEEEZARD7
Post  LEEEZARD7 on Sat Nov 10, 2012 7:01 pm
thanks rob for the advice. stuck the throttle body in the mill and clearanced it for hood angle.
LEEEZARD7
Post  Admin on Sat Nov 10, 2012 7:16 pm
Didn't know there was such a thing as a "944v8 Forum" ............... Shocked
Post  LEEEZARD7 on Sat Nov 10, 2012 11:02 pm
lol... sorry admin. this forum is what i was talking about. met rob today as he is practically my neighbor. live on the same street just about 15 miles away.
LEEEZARD7
Post  LEEEZARD7 on Sun Nov 11, 2012 8:26 pm
cut and milled the crossmember spacers tonight.
LEEEZARD7
Post  Tim on Tue Nov 13, 2012 10:10 pm
LEEEZARD7 wrote:lol... sorry admin. this forum is what i was talking about. met rob today as he is practically my neighbor. live on the same street just about 15 miles away.
In Oklahoma that is basically next-door lol
Tim
http://www.OEMPartHaus.com
Post  LEEEZARD7 on Tue Nov 13, 2012 10:29 pm
you must have been here huh lol.
LEEEZARD7
Post  LEEEZARD7 on Thu Nov 15, 2012 10:19 pm
my 40tooth cam gear showed up today. also purchased the gm vss sensor xschop quoted in his build. shouldnt take me an hour or so to set up a bracket assembly. thanks rob
LEEEZARD7
Post  LEEEZARD7 on Thu Nov 15, 2012 10:21 pm
on the hunt for the elusive audi 5th gear. i think i know where one is, we shall see tomorrow.
LEEEZARD7
Post  LEEEZARD7 on Sat Nov 17, 2012 11:07 pm
i got some very nice parts today. thank you rob. i have decided against the audi 5th gear. i will just either install a vette 6spd with torque tube and all or convert to g50/968/6spd with g5052 965 turbo gear sets.
LEEEZARD7
Post  LEEEZARD7 on Sat Nov 17, 2012 11:18 pm
ok so far, i have... motor mounts, crossmember spacers, adapter plate, trans mount, mc hydroboost mount, turbo radiator, l33 5.3 with ls1 intake setup, and na trans. still some pieces to go but getting closer.
LEEEZARD7
Post  LEEEZARD7 on Sun Nov 18, 2012 7:41 pm
ok... ordered a new 2004 mustang gt hydroboost with mastercylinder setup.
LEEEZARD7
Post  LEEEZARD7 on Mon Nov 19, 2012 11:15 pm
car will now have power brakes and power steering. both of which i originally wasnt going to do. i have a 1982 manual rack from a 924 if any one is interested.
LEEEZARD7
Post  LEEEZARD7 on Mon Nov 19, 2012 11:17 pm
also going to build my own pan from a truck stock oem aluminum pan. will cut it up and use 7075 1/4" plate and reshape and tig it back together. also will delete the need for a filter relocation setup.
LEEEZARD7
Post  LEEEZARD7 on Sun Nov 25, 2012 2:21 am
now have the vss sensor, gear, and bracket. have a new ls1 gear reduction 3hp starter. poly suspension kit.
LEEEZARD7
Post  LEEEZARD7 on Sun Nov 25, 2012 2:25 am
for weight reduction i have manual sport seats from a 78 911, manual 968 aero mirrors, converting to manual locks and windows and taking out necessary hardware. taking out all non essential parts/hardware/sound deadening. am going the rs america type route with the car. minimalistic but nice. will have ps, pb, ac, and a radio but thats it.
LEEEZARD7
Post  LEEEZARD7 on Sun Nov 25, 2012 10:35 pm
msd red coils coming soon...
LEEEZARD7
Post  acorad on Mon Nov 26, 2012 11:33 am
LEEEZARD7 wrote:on the hunt for the elusive audi 5th gear. i think i know where one is, we shall see tomorrow.
Did you get an Audi 5th? If so, which one?
Andy
