I Have 2 aluminum L33 5.3's and 2 aluminum LH6 5.3's for sale
hello, these are used motors but still very useable. these come stock with the 243 casting corvette heads with the smaller combustion chambers that alot of the hot rod guys like. longblock assemblies minus oil pans, minus accessories, minus injections. 1500.00 each. (if someone wanted better piece of mind, for about 450.00 more i could install new gaskets, head gaskets, seals, main and rod bearings, and rebuilt oil pump.) stock these motors are rated at 330hp at the crankshaft. very upgradeable with ls6 or ls2 cams, ls2 springs and valves, larger throttle bodies, and larger maf's, stainless steel headers, and a good tune... so on, so on... you can get good hp out of these little motors. if you mod them i would suggest better rod bolts, head bolts, and rocker bolts. or use them stock as is. obviously your choice. just my .02
LEEEZARD7- Posts : 148
Re: I Have 2 aluminum L33 5.3's and 2 aluminum LH6 5.3's for sale
Can you please send me some pictures of the 5.3L's?
I am looking for two Aluminum block 5.3L's one for each of my 944's
Thanks.
Thanks.
99sierra4x4- Posts : 121
Do still have any of these motors?
jwink25- Posts : 3
havent been on in a while... yes have one each. 1 l33, 1 lh6.
they are sold. thanks for looking
