944 s2 ...lexus v8 4.0 quad cam,32 valve v8 swop...
hi all not to good with speeches,but always wanted to put the lexus engine in something different,had alot of 944 s and a few buick/rover v8 versions over the past few years...
so i picked up this 1990 944 s2 for the bargain sum of £650 and then sold the engine for more than the price of the car...
so after a few emails to rob xschop,he kindly agreed to help make an adapter to mount the 1uz v8 to the torque tube...i received the adapter,which i may add is awesome...so to date,engine is out,manual flywheel is on,as is the clutch disc and pressure plate,heres a few pics and will update as project progresses...cheers...
beario- Posts : 42
Re: 944 s2 ...lexus v8 4.0 quad cam,32 valve v8 swop...
this morning,we drilled 2 holes on the top of the b/h so the clutch line and bleed would fit...as per pictures...
beario- Posts : 42
can anyone tell me when i add the pics it cuts them in half...
beario- Posts : 42
Hey Nigel, before you throw it all together, what is the diameter of the hole that goes thru the pressure plate fingers. Will be good to know if there is a difference between your plate and the 4-runner's plate. Looking good.
sorry rob its in the bay now...
beario- Posts : 42
beario wrote:can anyone tell me when i add the pics it cuts them in half...
Your pictures are too large. Condition your raw images first before uploading them with a standard program e.g. ms office.
can you do that as no idea how thats done...??if not i can delete thanks...
beario- Posts : 42
This time yeah, but not every time.can you do that as no idea how thats done...??if not i can delete thanks...
Use Firefox as your browser when you're on this site, and then right click on the pics you want to view and select "view image" and the entire pic will be displayed. Easy peasy.beario wrote:can anyone tell me when i add the pics it cuts them in half...
acorad- Posts : 697
» Lexus BBK Big Brake Kit
» *SOLD* Lexus big brake swap kit
» Cryo-treated 85.5 Hubs/Spindles for Boxster/Lexus swap
