2000 covette ps pump work with bmw hydro and stock rack?
+2
tkrame944
6 posters
i am now getting down to nearing the end of my build, and one of my next steps will be plumbing in my hydrobooster and rack. i have heard some about an aftermarket ps pump but i dont remember any details. right now i have a stock 2000 corvette ps pump with a 1983 bmw 740il hydroboost, and stock 1986 944 na rack. will thoes all work together or will the stock ps pump not run the corect pressure, or have correct lines.
tkrame944- Posts : 101
PS Pump
I'm using a Turn One PS Pump with Mustang HB and stock 944 rack.
So far so good.
So far so good.
Re: 2000 covette ps pump work with bmw hydro and stock rack?
If you plan on tracking your car you should get the Turn 1 pump. On the street the corvette pump will be ok...
My car will be a street car, but i want it to preform without hesitation. Will i be disapointed with the stock pump? How does it lack?
I'm Running a stock Camero pump with the BMW Hydro and 86NA rack.
The brakes are fine, they come on with a light touch and stop just fine.
You will need to run the BMW or equal size reservoir as the "bomb" holds about a dozen stops. Thats a nice size puddle of oil.
The steering is more consistent above idle so I guess the higher pressure pump would address that. I'm not worried about it for street use
Patb- Posts : 46
On the track the pressure the stock pump gives is wrong and the power steering fluid will boil. On the street it's not a problem.
sounds good thanks for the help. i will just use the one i have and my bmw resivior. and i could throw my porsche power steering cooler on also is that reconmended?
PS Reservoir
I switched my PS cooler from right to left side and plumbed it into the return line.
Did you use the original Porsche power steering cooler?
That sounds like a good set up I don't want to over heat anything when I go all out
tkrame944 wrote:i am now getting down to nearing the end of my build, and one of my next steps will be plumbing in my hydrobooster and rack. i have heard some about an aftermarket ps pump but i dont remember any details. right now i have a stock 2000 corvette ps pump with a 1983 bmw 740il hydroboost, and stock 1986 944 na rack. will thoes all work together or will the stock ps pump not run the corect pressure, or have correct lines.
I didn't think there was an 83 740iL?
» Power steering rack still fail after Turn one pump install....
» Stock Porsche P/S Pump on LT1
» Fittings (AN) or (JIC) for LS1 pump, Porsche rack, GM hydroboost?
