» Headers, headers, HEADERS!
» Electric brakes
944 s2 radiator???
944 s2 radiator???
Post  beario on Sun Sep 23, 2012 4:03 pm
hi was wondering is the 944 s2 3.0 radiator and good for cooling a v8???or wahts anyone else using...???is there a bolt in or same size rad thats fits thats more up to the job???any pics of what your using cheers...
beario
Re: 944 s2 radiator???
Post  acorad on Mon Sep 24, 2012 11:18 am
beario, I think if you do a search on this board for radiator you'll get many threads with tons of info.
fwiw, I originally had a RH rad but it hung so low it was always scraping the pavement and got damaged. I'm currently installing a shorter turbo rad as I've read that it will handle the LS1 fine.
Post  beario on Tue Sep 25, 2012 6:45 am
cheers thanks...
beario
Post  docwyte on Tue Sep 25, 2012 9:56 am
Turbo rad works well on the street. I have the RH/RD radiator now, it's better for the track. I haven't had the scraping issues with it, my splitter and air dam cover up the bottom of it and protect it somewhat. I also like the hose routing on it, you have to be careful with the turbo radiator to make sure the hoses don't get cut up, that isn't an issue with the RH/RD radiator.
Post  beario on Tue Sep 25, 2012 3:53 pm
im going to get the s2 radiator 2 or 4 cored with metal end tanks...
beario
Post  docwyte on Tue Sep 25, 2012 4:09 pm
Probably not worth it cost wise vs the RD/RH radiator...
Post  GudmundurGeir on Sun Nov 18, 2012 5:08 pm
Maybe I can use the original rad from my car , it's an s2 ? I'm located in Iceland and its a bit colder here than in the US ...
GudmundurGeir
Post  docwyte on Sun Nov 18, 2012 9:53 pm
The S2 radiator is the same as the turbo radiator. For street driving you should be fine with it...
