How to plumb in 951 rad for LS1?
I searched the site, but found little info on this.
How do I plumb in the 951 rad to an LS1?
A) What does that little breather pipe looking thing do/connect to?
B) This goes to the outlet of the water pump.
C) This 20mm brass threaded hole?
D) Looks like 23mm OD?
E) This goes to the water pump inlet.
acorad- Posts : 697
Re: How to plumb in 951 rad for LS1?
A) steam vent to overflow tank*
B) outlet to engine
C) fan temperature switch
D) inlet from overflow tank
E) inlet from water pump
* Some people tee this with the engine's steam vent. I did and it's cooling fine. Others block off this port on the radiator and run the engine steam vent by itself to the overflow tank.
B) outlet to engine
Rich L. wrote:A) steam vent to overflow tank*
B) outlet to engine
Well, dang, that was easy!
My fan temp switch on my old RH rad is much smaller thread dia than the brass location in my new 951 rad, is the correct sized 951 fan temp switch just a Pep Boys/Autozone type part?
acorad- Posts : 697
I've picked up those switches locally, that's a fair price from rennbay.
Thanks guys!
acorad- Posts : 697
Is "A" supposed to be open like a straw? Or kinda blocked such that air/water only breathe through it under pressure?
acorad- Posts : 697
It can be permanently blocked or t'd with the steam vent from under the throttle body going to the expansion tank.
