Yesterday at 9:03 am by chrenan
Fri May 25, 2018 8:34 pm by superman22x
» WTB: 944 Turbo Roller
Thu May 24, 2018 8:32 pm by knight76
Thu May 24, 2018 7:52 pm by matt889
» New here needing help
Thu May 24, 2018 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Wed May 23, 2018 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
May 2018
78910111213
14151617181920
21222324252627
28293031
GM Performance oil pan for swap?
Post  jfrahm on Wed Sep 19, 2012 7:41 am
Hi, I tried to search this site to see if this has been discussed but did not find anything. I wonder if this pan might work for a 944 swap:
Measurements:
The price is attractive and it comes with the windage tray and pickup.
Cheers,
-Joel.
jfrahm
Re: GM Performance oil pan for swap?
Post  Admin on Wed Sep 19, 2012 8:03 am
Sure it will work, You just need to cut the front sides to clear the steering rack and then you'll just have to make a skid plate to cover the 2+ inches that will hang below the cross member. Other than that , yes it will work. Laughing
Post  docwyte on Wed Sep 19, 2012 9:05 am
Joel,
If you ever want to check out my car, let me know.
Admin sells everything you need to do the swap in your car as a bolt in. If you want to fabricate stuff you can use anything as a base, but no commercially available oil pan other than Admin's is a direct bolt on.
Post  tkrame944 on Wed Sep 19, 2012 10:43 pm
I purchased a pan just like that if not the same and after putting it on and seeing how it fit compared to the crossmember i went and bough the custom made oil pan. With all the difficulties with mounting the rack even with the cusom oil pan, i would highly reconmend digging deep and investing in the custom pan.
But if you do decide to go with that pan i still have the one i bought and it is brand new i would sell it to you.
tkrame944
Post  Admin on Thu Sep 20, 2012 7:09 am
Jf,
If you give me about a week, I have the new pan with an filter adapter that does not need lines or remote filter. It's designed for the street car guy's, but it will have an adapter available for the racers as well. the adapter will allow lines to be added for coolers. Cool
Post  zeusrotty on Thu Sep 20, 2012 8:05 am
Just got my pan, oil filter relocation kit and new motor mounts from TPC... Good stuff! Now I just have to scrape up the dough for this rebuild!
zeusrotty
Post  xschop on Thu Sep 20, 2012 11:05 am
Get the TPC oil pan, can't go wrong there.
