Any one have Valve spring failure ?
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Tracking Your Car
It seen like a must check list on the LsX power car
i will check my during the winter.
the Ls1tech board make it sounds like a time bomb. if you are running different cam and single spring
Diyman25- Posts : 79
Re: Any one have Valve spring failure ?
That's why I went with a dual spring and titanium retainer setup. If not......you do have a time bomb....
the951racer- Posts : 135
I put in better bee hive valve springs when I put in the cam.
I have TR224 cam and Comp 918 with TSP 7.4 inch lifter
but a lot of source on line.. saying 918 spring is only good for around 20K
that is pretty hard to believe ???
but i guess i will just change it just be sure
J
J
We always recommend replacing the springs to a better spring whenever you change to a larger cam.
