clutch pedal stuck down
My 944 for sat for about a month. When I went out to work on it the clutch pedal stays at the floor. I have read that it is due to either the cylinder under the master cylinder or the cylinder next to the starter. i removed both and very carefully rebuilt both. I have checked for leaks but have found nothing. If i put a power bleeder on the hose that feeds the clutch I have pressure at the pedal and on the clutch face. But nothing bleeds from the bleeder on the bottom cylinder. Once I re-attach the line to the resevor i have no pressure again.
Any ideas?????
Any ideas?????
GAKFU- Posts : 1
Re: clutch pedal stuck down
What engine do you have?
Helper spring in place?
