» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
Any one did 0-60 in their hybird?
Post  Diyman25 on Wed Sep 05, 2012 4:18 am
I know our car is not design to drag it, but since i am still wearing my stock size wheel 16 inch
with 225/50/16. i think before i can twist any thing the tire will brake traction first
so i hook up my racelogic Vbox that i normaly use for my lap time device but it also can measure 0-60
so last night around 1:30 am i roll out to the industrial area near my house
dont really want to drop the clutch
so i keep rev around 1500rpm and roll it out first then WOT
not surprisely the tire brake traction but just for very very short time
and sec time when i shift up to 2th
i was suprise i get a 5.5 sec 0-60
despite i never pratice it. often ( i love track more then street drag)
i think with right tires.. the car can go easy under 5 sec
wondering did any one done this type of test before ?
J
Diyman25
Diyman25
Re: Any one did 0-60 in their hybird?
Post  docwyte on Wed Sep 05, 2012 8:51 am
I can easily keep up with a C5 Z06 (that has shorter gearing) in a straight line with my car. So I'd say my 0-60 is the same as his...
Post  Diyman25 on Thu Sep 06, 2012 4:58 am
docwyte wrote:I can easily keep up with a C5 Z06 (that has shorter gearing) in a straight line with my car. So I'd say my 0-60 is the same as his...
in my area, i think there is one ZR1 and mabe few C6.... we get a lot of M3, E55 or GTR,
i think i will take any GT3 for the lunch lo Wink !!
Did any one feel the 944/968 transaxle is hard to shift ? compare to tradional MT like Camero or mustang
i still cant use to
Diyman25
Diyman25
Post  Arthropraxis on Thu Sep 06, 2012 6:47 am
First to second on mine feels like there is a mechanical block then it shifts into gear. It doesn't grind there is a pause before it can get into gear. The other gears are fine. It seems like a common complaint on the Porsche forums.
Post  Modian on Tue Sep 11, 2012 1:11 pm
Arthropraxis wrote:First to second on mine feels like there is a mechanical block then it shifts into gear. It doesn't grind there is a pause before it can get into gear. The other gears are fine. It seems like a common complaint on the Porsche forums.
This bugged me for years but I recently found a way to alleviate ~90% of it by changing how I shift. Before, I would hold the shifter on the right and 1st to 2nd would be down with some pressure to the left, and I would always hit that blocking/pausing feeling.
I changed it so I hold the shifter on the top and make sure the shift is straight back with no sideways pressure. Doing it this way reduced almost all the blocking feeling I had. Giving it any pressure to left results in that pause again. I haven't tried it yet but I wonder if slight right pressure would avoid it completely?
Modian
