» Transaxle rebuild
» Tpc LS adapter plate
AC Question
AC Question
Post  fliermike45 on Mon Aug 27, 2012 4:54 pm
Before I put my 948 into storage I was chasing a AC leak. I could not find a leak in the engine bay, compressor or radiator areas.
Has anyone any experience of ac leaks under the dash and where to look for them?
Re: AC Question
Post  87-944S on Mon Aug 27, 2012 5:19 pm
Hey Mike, get a can of the A/C refrigerant with dye in it and the glasses, etc. It's cheap, available at Advanced, Pep Boys, etc, and you will save a ton of time looking for the leak. I've used this before, worked like a charm.
Re: AC Question
Post  948 on Mon Aug 27, 2012 11:13 pm
As the other mike said a UV dye is a must......
The best way to see, and change out, the expansion valve (and connections) is by removing the HVAC blower cover in the rain tray. I don't remember if you can see much of the evap core though.
If you haven't already changed the expansion valve, this would be a good time to do it.....I picked that and a dryer up from Polar Bear Inc.....you will also want some cork filled insulation tape, to wrap up the valve and lines afterwards.
Re: AC Question
