Engine PCM and Tune
Engine PCM and Tune
Hi guys before I begin let me apologize for the noob question.
I saw a truck at the recycle yard with an lm7 motor and it had the 12200411 ECM. Now my question is can I get this ECM and have the vats removed and use it as a starting point for my conversion. And also what ECM is everyone using and the tune to go along???
Punisher948- Posts : 39
Re: Engine PCM and Tune
Yeah, thats the more desireable PCM as it can do both DBW and DBC. I would grab it if you can.
Mark
Mark
Marky522- Posts : 175
Shameless plug, you could buy my PCM that is already programmed with a stand alone tune for this conversion. It is in the for sale section.
Thanks for the response
I have a 12200411 PCM albeit I don't know what is come out of as GM used that number for a long run.
I was just thinking that this one will have a tune that is pretty close, hopefully close enough to start (even though I’m light years away from that point) and if so why not just buy the thing and add it to my pile of parts. Like women and shoes I just can’t seem to pass up a good deal on parts. Thinking I could get the thing for $20-30. Weigh in guys looking for some feedback. Thanks
» Newb 944S LS1 Conversion
» Running rich???
» Running rich???
